Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: CAT 5, Burial Rated, Fire Alarm Cable
  1. #1
    Join Date
    Aug 2009
    Central NC
    Posts
    1,778
    I'm doing the office trailer at my church I mentioned recently in another category.
    They want me to bury conduits for phone/data, maybe fire alarm too. I may be limited to 1 1/4 PVC, as someone boring under the driveway is limited to 2" bit. I may be able to get 1 1/2, but doubtful, it is right at 2" OD.
    Anyone here familiar with CAT 5 rated for underground conduit/burial? How much thicker is it than standard CAT 5? How many could I get into an 1 1/4 conduit about 150 feet long with 3 90's? Do they make a CAT 5 with 25 pairs or so? If so, how thick is it?
    Yes, I'll be happy to do a first class job for less than anyone else and take a dollar a week for 10 years.
  2. #2
    Join Date
    Jul 2006
    Posts
    2,571
    Depending on what you need, fiber may be a better solution (smaller jacket for more pairs). I have also used 25-pr cat4, it was maybe 1/2" diameter. Not common, though.
  3. #3
    Join Date
    Aug 2009
    Central NC
    Posts
    1,778
    I don't remember CAT 4. 3 & 5 were in use when I 1st studied this at all. 3 of course, is history now for new installs. I've seen a little CAT 6, has plastic divider separating the pairs.
    Fiber hasn't been mentioned. The little I've been involved with that, we had to do wide radius 90's everywhere. Not practical in this application.
    I forgot to ask if there's any reason shielded fire alarm cable couldn't be run in the same conduit.
  4. #4
    Join Date
    May 2010
    Inside the Beltway
    Posts
    623
    Fiber is always a good idea between buildings.
    That said, why so many CAT5's? Put a switch in the trailer. [That is an Ethernet switch...]
  5. #5
    Join Date
    Nov 2009
    Moore, OK
    Posts
    432
    Quote Originally Posted by jmellc View Post
    Others may have more knowledge, but after readin Article 760.26, it seems you can have your fire system cable mixed with other types of circuits as long as the conductor insulation is all rated for the max.
    -Mark
    Industrial Occ. Safety & Health
    "Remember to pillage before you burn"
  6. #6
    Join Date
    Jan 2009
    NH
    Posts
    1,736
    Job Specs and I personally hate mixing Fire with anything else. IMHO of course.
    Check with the FACP manual also.
    And dont forget 760.32. Your gonna need transient protection on both ends, unless they are nonconductive (fiber, non shielded)
  7. #7
    Join Date
    Nov 2005
    Canterbury, New Zealand
    Posts
    1,877
    You really want that horrible jelly filled cable the telco boys use for use for undeground runs. The standard stuff will eventually get soggy and degrade.
  8. #8
    Join Date
    May 2010
    Inside the Beltway
    Posts
    623
    It's called icky-pic, for Plastic Insulated Cable.
    And if you insist on copper; that is true.
  9. #9
    Join Date
    Nov 2009
    Opelousas, Louisiana
    Posts
    588
    There are outdoor rated cat5's that are not gel filled. They are rated for above-ground, aerial, and in conduit. Conduit fill would be 10 in 1 1/4". I also would not mix fire alarm and data in the same conduit.
  10. #10
    Join Date
    Aug 2009
    Posts
    13
    Fiber? Video -
    Here's a video I found on pre-terminated fiber cable. In case you don't know how to terminate fiber yourself. Running fiber would save on space.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
