Results 1 to 4 of 4
Thread: Fire Pump
  1. #1
    Join Date
    Apr 2004
    ridgewood, n.j.
    Posts
    361
    Fire Pump
    Is having a fire pump on it's own electrical service in a industrial plant a requirement for insurance or some building code ? Is there a monitary advantage with Insurance companies when a fire pump has it's own electrical service ?
  2. #2
    Join Date
    Feb 2010
    Posts
    837
    Typically when the fire department comes to a building to put the fire out, they shut the electric service off. If the fire pump was on the main building service then it would be shut off with everything else. Having the pump isolated allows the department to shut everything off outside the building but keep the fire pump on. Pretty sure that is in the NFPA somewhere. Not to mention that it just makes sense.
  3. #3
    Join Date
    Jul 2003
    "I have learned, in whatsoever STATE I am, therewith to be content". :) Philipians 4:11
    Posts
    2,226
    Quote Originally Posted by puckman View Post
    Check out NEC 2008 695.3(1) specifically.
  4. #4
    Join Date
    Feb 2003
    Illinois
    Posts
    23,464
    Take a look at 695.3(C), a new section in the 2011 code. The code recognized that it would be almost impossible to comply with the previous rules in large "campus" type installations so this section was added.
    Don, Illinois
    Ego is the anesthesia that deadens the pain of stupidity. Dr. Rick Rigsby
    (All code citations are 2017 unless otherwise noted)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
