Results 1 to 4 of 4
Thread: Free arc flash calculation speadsheet/tools?
  1. #1
    Join Date
    Jun 2007
    Posts
    713
    Anyone know any available free spreadsheet/tools to do quick arc flash calculation out there?
  2. #2
    Join Date
    Sep 2008
    UK
    Posts
    10,542
    Quote Originally Posted by anbm View Post
    This was sent to me recently:
    http://www.arcadvisor.com/pdf/DukeHe...latorGuide.pdf
    http://www.labelprinters.org/duke-po...alculator.html
    The usual disclaimers apply.
  3. #3
    Join Date
    Jan 2009
    Maryland
    Posts
    13,149
    Found this, but I would not trust anything that was not engineered by an EE or a qualified person( Zog or Brian John for example)
    http://www.littelfuse.com/arccalc/calc.html
    "Electricity is really just organized lightning." George Carlin
    Derek
  4. #4
    Join Date
    Apr 2011
    Nashville, TN
    Posts
    66
    Quote Originally Posted by Besoeker View Post
    Just running some of these numbers along aside my E-Tap software. It seems really close. You just need to figure the following out for each panel.
    Arcing Current:
    Arching Distance:
    Arching Voltage:
    Working Distance:
    Clearing Time:
    So it would put more pressure on the engineer doing this calculation to make sure he has the right TTC curves.
    I think the hardest thing would be to find would be the arcing current at that panel, it could change depending on what cables breakers and fuses you had.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
