mstrlucky74
- NJ
My question in NOT regarding the new tap conductor feeding the new EMRP panel.
So the new EMRP panel will feed the extg. branch ckts that were being fed from the (2) RP-T3 panels which are being demolished. In my mind the two option to achieve this are:
1. Remove the interiors from the demolished panels and use them as splice boxes and extend the wring to the new EMRP panels. But I'm not sure if I can do that because I don't have a floor plan so I don't know if the new EMRP panel is going in the same location as the demolished panels.
2. Disconnect the extg. branch circuits. and cut/disconnect the branch conduit to a point on the wall or ceiling, install a splice box and extend from there to new panel.
Sound about right? Thanks.
