Results 1 to 5 of 5
Thread: Daisy Chain receptacles?!
  1. #1
    Join Date
    Jul 2003
    "I have learned, in whatsoever STATE I am, therewith to be content". :) Philipians 4:11
    Posts
    2,230
    I know it's legal, but in my opinion it's really bad practice and can't seem to figure out why they did this. I could even see if it was a gfci feeding some downstream receptacles, but in this case it's not. Maybe someone is too lazy/cheap to buy wirenuts.
    On a (commercial) job here recently someone had previously 'daisy' chained all the receptacles, basically if one of the receptacles go bad it will take out the other receptacles downstreamed from it. There are alot of them like that.
    Only code restriction I know of is for mwb circuits where the neutral continuity cannot depend on the device, so in this case they are legal since its not a mwb. I kinda wish it was a violation with only a few exceptions (ie gfci)
    Any one else wire their receptacles this way and if so why???
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,969
    It's just an installation practice but we always pigtail all of our devices MWBC or not.
    Rob
  3. #3
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    For us it depends on the job, both ways can last forever or fail quickly. That is really determined by the installer not the method.
  4. #4
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,557
    We Daisy chain almost everything but mwbc if using solid wire, otherwise pigtails.
    Tom
    TBLO
  5. #5
    Join Date
    Jan 2008
    Posts
    8,955
    Quote Originally Posted by ptonsparky View Post
    ditto
    BB+/BB=?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
