Brian O'Neill
- Fostoria, Ohio
I am currently installing a ground fault protection system in a marina. The manufactures recommendation is that it be connected upstream of the main disconnect. However the A/E on the project has stated that this would be in violation of NEC 230.82(8). I thought that exception number 8, clearly stated that it was permissible to do this, provided there was a proper disconnecting means. Any thoughts?
