Results 1 to 7 of 7
Thread: article 210.4 2008 nec
  1. #1
    Join Date
    Mar 2010
    Posts
    131
    i understand this article when installing multi wire branch circuits.
    question what if let say you install 6 circuits with 6 neutral in the same conduit entering a panel .does each circuit and neutral have to be identify as they enter a panel cant find where it says that.
  2. #2
    Join Date
    Jan 2009
    Maryland
    Posts
    13,146
    I do not know of a code section requiring this identification of individual grounded conductors of circuits.
    Do not find anything in 2011 either.
    "Electricity is really just organized lightning." George Carlin
    Derek
  3. #3
    Join Date
    Apr 2009
    Olathe, Kansas 338 mi SE of Wingedhorses
    Posts
    2,725
    No it's not required. But it might make it easier on the next guy if they were
    identified with sticky number wraps, especially if the next guy is YOU.
    Electricity is Color Blind
    Leave the shirt pocket rules in your pocket.
  4. #4
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    32,521
    It really is not different than 6 mc cables entering the panel. Now I believe each neutral should be identified with the appropriate ungrounded conductor.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  5. #5
    Join Date
    May 2007
    West Virginia, USA NEC: 2008
    Posts
    1,971
    Quote Originally Posted by Dennis Alwon View Post
    following 210.4(D) each neutral of the circuit will be identified by the grouping.
    Jack
  6. #6
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,162
    Quote Originally Posted by Twoskinsoneman View Post
    That does not apply to the two-wire circuits mentioned in the OP.
    Rob
  7. #7
    Join Date
    May 2007
    Posts
    1,971
    Quote Originally Posted by grumpy11 View Post
    Quote Originally Posted by infinity View Post
    Fooled by the title of the thread saying 210.4
    Jack
Posting Permissions
  • You may not post replies
  • You may not edit your posts
