Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: ADA height for receptacles and switches
  1. #1
    Join Date
    Dec 2008
    Posts
    202
    ADA says 15" min for receptacles. This would mean 18" from finish floor to the top of the outlet box. I recommend that we all measure 19" to the top from the sub-floor. This allows for hardwood floor installation.
    For switches, ADA says 48" max. I recommend 42" to the top of the box in order to avoid the drywallers filling the box with mud.
    Any comments or suggestions?
  2. #2
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    14,191
    Go for it.
    "Electricity is really just organized lightning." George Carlin
    Derek
  3. #3
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    32,980
    Quote Originally Posted by mlnk View Post
    Why are you recommending the height that you like. Most plans have the heights specified. Personally I like 19" to the bottom for recep. because my stick rule opens to that height and I can mount the box right on top. As for switches I like 43 to the bottom for the same reason. In residence I use 13" to the bottom for receptacles & 43 to the bottom for switches. That is pretty standard around here.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  4. #4
    Join Date
    Dec 2008
    Posts
    202
    Why not go 16" to the bottom of the box and be ADA compliant? Of course i am recommending what I like, but it is also ADA compliant...
  5. #5
    Join Date
    Jul 2004
    Ca and Wa
    Posts
    1,507
    Yes...measuring from the center of boxes AFF is usually done to avoid misaligned box levels, especially in tile. Reason: Not all manufacturer box envelopes are the same. A metal foursquare with mudring and single gang plastic are different as is a cut-in box. The ADA is project specified. Setting wall switch heights at 42" is standard above a 32" bath lav counter, in a kitchen 42" will not usually work with a 36 inch cabinet plus counter height. The floor and custom counter thickness will almost always be a negative clearance with the wall plate.
    rbj, Seattle...Safety is a Professional Courtesy.
  6. #6
    Join Date
    Dec 2008
    Posts
    202
    Excellent point about measuring box heights O.C. ...... Of course kitchens heights vary. Also, Where customer has not decided about backsplash/tile, i like to use the adjustable set out boxes..a great invention.
  7. #7
    Join Date
    Nov 2007
    Louisville, KY
    Posts
    433
    I would like to see a link to these. Not sure I know what they are and Google didn't help today.
    Dale
  8. #8
    Join Date
    Dec 2005
    WI & AZ
    Posts
    2,085
    Quote Originally Posted by gndrod View Post
    I've never had a problem setting kitchen countertop receptacles at 42". The houses I've done have 36" counter heights and a 4" backsplash.
    Tom
    " And all the science I don't understand, it's just my job five days a week "
  9. #9
    Join Date
    Dec 2005
    WI & AZ
    Posts
    2,085
    Quote Originally Posted by dhalleron View Post
    Carlon makes both single and two gang adjustable boxes. Very handy for a variety of situations.
    Tom
  10. #10
    Join Date
    Nov 2007
    Louisville, KY
    Posts
    433
    Duh. I guess I missread post #6. I thought the box somehow adjusted up and down for the the backsplash height off the counter. I wondered how that was going to work.
    Dale
Posting Permissions
  • You may not post replies
  • You may not edit your posts
