Does anyone know if you can get a 4 way configuration in a Despard switch?
I tried to pull up Legrand/ Pass and Seymour website but can't find their Despard product line.
Any help appreciated
Stud cavity width only allows for existing single gang box to be fished into. It already has a conventional 4 way switch in it.
Customer does not want another box added to the wall.
I guess it all depends on how bad they need/ want the convenience of the additional 3 way switching capability.
Standard building practices have 16 inch spacing between studs. Are you saying a two or three gang boxes would not fit between studs?
Not all studs are placed sixteen inches apart, especially near doors where it's common to put a switch.
Standard building practices have 16 inch spacing between studs...
Wiremold 1 gang to 2 gang extension box?
Works but butt ugly.
I need to have (1) 4way switch and (1) 3 way switch occupy the same single gang box. Was hoping to be able to get (1) Despard 3 way and (1) Despard 4way . Mount them in the Despard yoke and call it good.
More potentially ugly optionsThat's real butt ugly and a lot of homeowner's are not going to go for it.
It's a simple reversing switch that changes whether the 3-ways are connecting the commons to the same traveler. If they are, it changes them so they're not; if they aren't, it changes them so they are.Not a single schematic of what's inside the switch.
Am finding Despard does not make a 4 way insert that snaps into their yokes
