DOes anyone know what a "sweep" of RF cabl;e would entail/mean? Thanks.
Bending radius. Sweep elbows/ells are more gradual in the turn.
"Electricity is really just organized lightning." George Carlin
Derek
Or testing the cable with a signal generator and analyzer to make sure the cable is within spec
Gregg
I'm just here for the pictures!
It tests the cable (usually coax) to see if it is within manufacturers specs. Coax can be damaged by improper handling, dents, tight bends, water ingress, high heat, age- any number of things. These things will often show up as increased attenuation at some or all frequencies depending on the defect. A sweep test applies a fixed level variable frequency signal to one end of the cable that is measured and recorded at the other. The variable frequency begins at the lowest frequency you want to measure and ramps up to the highest frequency. An X/Y axis graph is generated by the sweep receiver at the other end- frequency vs attenuation. You can then compare that to the graph provided by the manufacturer or see right off what some problems are by their "signature".
Another useful test is with a TDR that will actually show where along the cable any problem is.
-Hal
Sorry Horsegoer, I saw sweep and thought you were talking about installing IT cables in conduit.
IT types are always specing oversized conduit and sweep elbows.
Derek
Thanks, Hal for answering while I was out inspecting an AM transmitter site...you 'splained it better than I could, anyway.
Our Fluke DTX1800 can sweep coax up to 900MHz as part of its testing, although we didn't buy the coax interface kit...we just use it to certify our CAT6 runs.
Gregg
What we need is more IT guy engineering and less value engineering. That would be a way to fuel the economy.
If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
Bookmarks
