Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Lag Screws
  1. #1
    Join Date
    Aug 2009
    Central NC
    Posts
    1,756
    Lag Screws
    I may have to find another place to buy lag screws. I installed a strut yesterday with 2 1/2 inch galvanized lags I bought at Big Blue. Popped the head on 3 & I know I wasn't turning that hard. Popped about where the threads begin, 1/2" or so from head. I see that with toggle bolts too sometimes.
    Maybe Fastenal has a better quality screw. None of our local supply houses usually have lags.
    Yes, I'll be happy to do a first class job for less than anyone else and take a dollar a week for 10 years.
  2. #2
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    14,190
    Ya gotta pay attention to the markings on the head to tell what grade bolt you are getting for the application you are using them for.
    "Electricity is really just organized lightning." George Carlin
    Derek
  3. #3
    Join Date
    Feb 2003
    NE Arkansas
    Posts
    2,221
    I don't think lag bolts use the head marking code you find on machine bolts.
    I stopped using ordinary lag bolts over a decade ago. Instead, I use the ones made by Simpson Strong-tie, and usually stocked with the Strong-tie connectors, rather than in the nuts & bolts aisle.
    The Simpson bolts have washered hex heads, which are a natural for driving with an impact driver.
  4. #4
    Join Date
    Sep 2004
    Durham, NC
    Posts
    5,500
    Quote Originally Posted by renosteinke View Post
    I don't think lag bolts use the head marking code you find on machine bolts. ...
    Understanding and correctly using the marking code is a small science in itself. JMO
    Lag bolts are cast not rolled or machined that one finds at a big box store.
    If you are even thirsty, you are two quarts low.
  5. #5
    Join Date
    Jul 2005
    Gainesville, Florida
    Posts
    1,052
    Hammertime
    I watched a lineman nail one in with a hammer instead of using a ratchet. Worked pretty well. That was before battery impact drivers.
  6. #6
    Join Date
    Feb 2003
    Huntsville Alabama
    Posts
    2,139
    Quote Originally Posted by GUNNING View Post
    I always thought that the threads were just for removal.
    Some people are like slinkies. They serve absolutely no useful purpose. But still put a smile on your face when pushed down a flight of stairs.
  7. #7
    Join Date
    Aug 2009
    Central NC
    Posts
    1,756
    I haven't seen many hammer type lags in recent years. We used to use them in the 70's to mount pole lights & other things. They usually had a square head & threads were long spiral type, more like a spiral shank nail.
    Next time I'm near Fastenal, I'll see if they have galvanized lags & buy a small box or bag of them.
  8. #8
    Join Date
    Dec 2006
    Eastern Oregon
    Posts
    3,480
    Are you predrilling?
  9. #9
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    35,488
    The ones that they do that with are designed for that. They are harder steel and threads are designed to slip into the pole easier but will need to be turned to remove them.
    Try doing that with typical hardware store lags in a hard new pole and you will only enter the pole slightly and will probably eventually break the bolt.
  10. #10
    Join Date
    Aug 2009
    Central NC
    Posts
    1,756
    Quote Originally Posted by Cow View Post
    Yes, a size below 3/16", for a 1/4" lag. 5/32" I think. I always drill for anything larger than #12. They all snapped about the same place, about a 1/4" before the threads.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
