I need some help clarifying something. We design many projects where we use a standby generator to provide emergency power to egress lighting. Typically we use a generator transfer device such as the Bodine GTD so that the emergnecy lights can be switched with the normal power lights, but still automatically come on upon loss of normal power.
NEC 700.20 clearly says that emergency lighting cannot be connected to a 3-way switch. Does this requirment still apply when you use a generator transfer device since the device brings the lights on automatically regardless of switch position? thank you.
Bookmarks
