hhsting
- Glen bunie, md, us
- Junior plan reviewer
Would this be a feeder tap of tap:
I have incoming utility entering inside tenant space room #1 to 600 amps main service breaker 240v, service voltage 120/208v. The load side of the service breaker feeders are tapped at point #1 and #2 with fused disconnects at the tap points #1 and #2. Point #3 has no fused disconnect or has no breaker and its greater than 25 feet goes to different tenant space room #2 in same building which is 80 feet away and lands in a main breaker at the tenant space room #2. The load side of the main breaker, feeders are tapped again at different four points with four fused disconnects at tap points. Is load side of tenant space #2 main breaker feeder consider tap of a tap?
