Originally Posted by
macmikeman
You can get a double ended male microphone (audio) cable from Radio Shack for under twenty dollars. You plug one end into the headphone jack on the laptop and the other end into the microphone jack on the laptop. Then use Quicktime (mac) or whatever it is Windows provides in the operating system to capture the movies as a screencast. Once you get the hang of it, you can do some really cool stuff, like flawlessly stringing video clips together to make a longer movie out of it. My Ipod is full of training clips I strung into movies I can listen to all day at work if I'm in the mood for it. Just don't attempt to resell anything...
Not sure about an I-pod but I doubt very much you can send video files through your audio card on a PC? which is what the head phone and mic jacks run through??? matter of fack connection the mic to the headphone jack in most cases will send the audio card into a feed back loop and can damage the audio card if the mute is ever opened.
Many times the video file is being downloaded to a temp file as it plays, if you get good at timing to copy right after the whole file is downloaded (buffered) and can locate the file in the temp files, you can grab a copy and paste it into another folder before it is erased.
Wayne A. From: N.W.Indiana
Be Fair, Be Safe
Just don't be fairly safe
Bookmarks
