Results 1 to 3 of 3
Thread: DROP VOLTAGE
  1. #1
    Join Date
    May 2008
    Posts
    2
    DROP VOLTAGE
    Hi everyone, I am taking the Florida Unlimited Electrical Contractor examination by May and I don't really know which Drop Voltage method I should
    use since there are three different method in my books and everyone gives different results. My question is : which method they (Pearson Vue)
    are using for calculate their results/answers ?
    Thanks.
  2. #2
    I would assume that even though the answers come out different that the numbers are close. i would imagine you could safely round your answer using any of these methods and get the correct answer. use the one thats easiest for you
  3. #3
    Join Date
    Apr 2010
    Trenton, Florida
    Posts
    31
    Answers
    All 3 should be the same.
    If it seems like it was too easy, double check, you probably screwed up!
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
