Originally Posted by
rmann
When we measured the currents, the neutral was almost the same as the hots. what gives?
That question has been answered. But let me suggest that you take the same two phase wires that you used for your experiment and connect them instead to the primary of a single phase transformer. The voltage ratio is not important, but for discussion sake let us say the secondary voltage is 120/240. Try your experiment again, this time using the transformer secondary as your voltage source.
Charles E. Beck, P.E., Seattle
Comments based on 2008 NEC unless otherwise noted.
Bookmarks
