Results 1 to 7 of 7
Thread: Fire Alarm DACT monitoring
  1. #1
    Join Date
    Mar 2010
    Posts
    245
    Some questions on commercial fire alarm system monitoring:
    Most fire alarm panels have a DACT that can transmit in a variety of formats?
    Including Simplex?
    Do most monitoring companies monitor a variety of formats?
    Can a typical receiver (at the monitoring company) monitor more than one format?
    Simplex monitoring services only monitors simplex fire alarm panels (and other simplex equipment)?
  2. #2
    Join Date
    Feb 2003
    New York, 40.7514,-73.9925
    Posts
    4,454
    Do you mean simplex type communications as opposed to duplex, or Simplex the manufacturer?
    Ron
  3. #3
    Join Date
    Mar 2010
    Posts
    245
    Simplex the manufacturer.
    What are simplex and duplex communications in this context?
  4. #4
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,614
    Quote Originally Posted by olc View Post
    Including Simplex?
    Yes.
    Yes.
    Yes.
    Yes.
    No. (Money is money. They'll be glad to take yours.)
  5. #5
    Join Date
    May 2012
    albuquerque,nm usa
    Posts
    4
    Alarm formats
    Most fire alarm panels are capable of different communicator formats. Older fire alarm DACT dialers used 4x2 format. Newer fire panels will use Modem 2 format or contact id. The fire panel can send many more signals with this type of format. Central station receivers are capable of receiving multiple formats including the older 4x2 formats.
  6. #6
    Join Date
    Jul 2006
    central nc
    Posts
    360
    If its a different type panel than they are used to monitoring or dont have one then you send over a Dialer Report that shows what the signals mean when they receive them
  7. #7
    Join Date
    Oct 2008
    Posts
    5
    Alarm Monitoring
    your question is a good one, and fairly straight forward.
    Yes, most alarm receivers that monitoring companies use will accept several formats. The preferred formats are the faster modem type like, Contact ID or SIA. However the Internet based communicators now being used by most companies are priority and if you have a specific brand, like Honeywell, Silent knight etc you need a specific receiver for them. In the future we will see all brands use similar formats here also but for now they are brand specific.
    good Luck DJ
Posting Permissions
  • You may not post replies
  • You may not edit your posts
