Closed Thread
Results 1 to 5 of 5
Thread: 200amp service
  1. #1
    Join Date
    Apr 2012
    california
    Posts
    2
    200amp service
    So i have two questions about a 200amp service. It feeds a 100amp panel and a 60amp subpanel in a granny unit in the back. I was wondering how can i split the panel to have a duel meter panel one for the main house 100amp panel and one for the 60amp subpanel for the granny unit.My second question is whats the best panel for this application. The main panel is on the exterior wall of main house.any input would be great thank you.
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    23,772
    You can get use 2- 100 amp meter bases and install 2 disconnects that fed each unit.
  3. #3
    Join Date
    Oct 2011
    Dallas, TX
    Posts
    157
    Another option is to get an aftermarket metering device that can be used to monitor the power use of the second unit.
    Downside is you have to keep up with the energy usage yourself (If this is to be a sublet situation).
    The Man Prayer: I am a man ... I can change ... If I have to ... I guess.
  4. #4
    Join Date
    Apr 2012
    california
    Posts
    2
    Thank you guys
  5. #5
    Join Date
    Dec 2008
    Posts
    146
    Where I live you can have a two meter service read by the utility if the granny unit is built with a permit. If it is a bootleg unit, as is common around here because the fees for a second unit are over $30,000, then you will need to install an owner read meter. Also , we are not allowed to charge for electricity based on a private meter or an estimate of percentage usage, the apartment must be rented "utilities included"
Closed Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
