Closed Thread
Results 1 to 10 of 10
Thread: Electrical plug cover?
  1. #1
    Is there an electrical plug cover similar to this http://www.amazon.com/KidCo-Kidco-Ou.../dp/B001SKKW0E for industrial applications?
    My client wants a cover for an outlet that will ensure that no one can come buy and accidentally kick the cord and unplug it. Apparently a twistlock plug & outlet won't do.
  2. #2
    Join Date
    Oct 2008
    Nebraska
    Posts
    312
    I can't imagine that standing up to much abuse. These work alright, they are "wet-in-use"covers but I use them in a few places in our plant to protect the cord cap. They can take a decent amount of abuse.
    Deserve's got nothin' to do with it.
  3. #3
    Join Date
    Jan 2009
    Easton, Maryland NEC: 2011
    Posts
    6,617
    What's wrong with a wall anchor and ty wrap on the cord?
    "Electricity is really just organized lightning." George Carlin
    Derék
  4. #4
    Join Date
    Feb 2003
    Massachusetts
    Posts
    45,307
    400.8 Uses Not Permitted. Unless specifically permitted
    in 400.7, flexible cords and cables shall not be used for the
    following:
    (4) Where attached to building surfaces
  5. #5
    Join Date
    Oct 2008
    Nebraska
    Posts
    312
    Forgot to add the link to my previous post:
    http://www.intermatic.com/Products/W...le_Covers.aspx
  6. #6
    Join Date
    Jan 2009
    Posts
    6,617
    Quote Originally Posted by iwire View Post
    following:
    The wall anchor is attached to the building surface, not the cord. JK
    As long as the cord can be disconnected, not a problem IMO. Violation yes, unsafe no
    Derék
  7. #7
    Join Date
    Feb 2005
    NJ
    Posts
    9,328
    Quote Originally Posted by Machiavelli999 View Post
    If the client is that concerned with the cord getting "kicked out accidentally" and unplugging some equipment, maybe the recept. should be closer to the equipment or feed in a different manner [overhead?]. ?
    ĦĦĦĦĦĦĦĦĦĦĦĦ
    ««« CELTIC »»»
    ĦĦĦĦĦĦĦĦĦĦĦĦ
    An error on your part does not constitute an emergency on my part.8-)
  8. #8
    Join Date
    May 2010
    Posts
    604
    And how a WP while in use cover would protect it from being kicked? Mind you, even the Aluminium ones, are not that strong.
    I would suggest two things:
    1: Use something like these:
    Name:  recessed receptacle.jpg
    2: Or, install an extender over the receptacle(they make these 1900 extension rings where the back of the box has a hole the size of a handy box), run a cord bellow the box and use a twistlock. I just did this couple weeks ago where the customer had a movable refrigerator(rather large) and they kept pushing it against the cord and the connector and the receptacle got damaged.
  9. #9
    Join Date
    Jan 2009
    Posts
    6,617
    Strife, you got a link for that product in the picture?
    Derék
  10. #10
    Join Date
    Apr 2009
    Kansas
    Posts
    1,272
    Try here an Arlingto producthttp://www.aifittings.com/products/spec-sheets/tvb712.pdf
    Electricity is Color Blind
    Leave the shirt pocket rules in your pocket.
Closed Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
