Ansul system
liquidtite
Ny
Doing an ansul system was looked up some diff installs online .
one way showed that you can Have the exhaust not have the option of being switched off
when in alarm mode by bringing steady hot to the n/o on the mocroswitch and then it will
keep the exhaust on even if someone turns of switch .
is this code or just a common practice .
the way o have it wired now is the switch turns on makeup air and exhuast at the same time
the switch leg Turns on exhaust coil and is spliced in Parrel to the common on the micro and
n/c bring power back to the makeup air coil to turn on make up air .
so if alarm goes on ,makeup air shuts off and exhaust stays on Bc it’s not wired I series with
micro switch . But it still give option to turn off exhaust in alarm mode.
should i I bring the steady hot feed to the n/0 so if someone turns off switch
exhaust will still stay on.
rambojoe
phoenix az
Wireman
there is a very very good thread about ansul systems from around 2016. ill try to paste it here for you.
edit- oh... it was a post you started! oops.. I couldn't paste it, sorry
Little Bill
Tennessee NEC:2017
Semi-Retired Electrician
I wire them that way because it's required that the make up air go off during an alarm/fire but the exhaust must stay on.
luckylerado
Exhaust is not required to be shut down on alarm but I do not read the code to say it is required to stay on either. Certainly makeup air is to go down and the gas is supposed to be wired to the controller to shut off as well as shunting power under the hood but whether the exhaust shuts down, stays on or comes on in my experience is an AHJ call.
NFPA 17 for dry and 17A for wet systems is where I recommend looking for code language.
liquidtite
Ny
Ok thanks for reply’s so what I gathered from
the post were that it’s not a code thing to have the exhaust wired
so it cannot be turned off in alarm mode just a good idea .
Anouther question I have . How many amps are the micro switches
usually rated for , and how many usually come with a single basic system .
also what need to happen when system goes into alarm mode as far as the fire alarm
aspect is concerned .
Little Bill
Tennessee NEC:2017
Before you dismiss that the exhaust must remain on you should contact the AHJ (or Fire Marshal in my case) to see what's required in your area. They can also tell you what else needs to happen such as what all needs to be turned off, including gas.
LarryFine
Henrico County, VA
Electrical Contractor
Oh Larry where are you?
Calling Mr Fine!
You rang?
I have wired many hood systems, both new and upgrade. When system trips:
The exhaust fan must turn on (in night mode) or stay on.
The make-up air must turn off or stay off (in night mode).
Any electrical appliance or outlet under the hood must lose power.
Gas valve must turn off when system trips. Must be manually reset.
If gas w/solenoid valve w/reset box, exhaust must be on for gas to flow.
If gas w/mechanical valve, must have T-stat in hood activate exhaust.
Horn/strobe or connection to building fire alarm system must activate.
I drew this a long time ago:
LarryFine
Henrico County, VA
21 amps is what I have seen, and they're only switched under load during testing and actual fire situations.
See my previous post.
