Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Ufer?
  1. #1
    Join Date
    Aug 2010
    Tennessee
    Posts
    101
    Ufer?
    Working on a new resi build at the moment. The basement walls have been prebuilt and are setting on a crush/run gravel base. I placed a 5/8" grnd rod under the walls so that we could tie into the rebar. Come to find out, they wont be using any rebar, it will be fiber reinforced concrete. Should I just span a 20 ft piece of #4 copper or do you have any other suggestions. Thanks
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,974
    I would just install 2 ground rods and call it a day.
    Rob
  3. #3
    Join Date
    Dec 2010
    Posts
    1,505
    Quote Originally Posted by infinity View Post
    I agree. Why make it any harder than it needs to be.
  4. #4
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    14,191
    I would pull the rod and drop in 20' of #4 with enough extra to reach panel. Easier to toss wire in trench than pound/drive 2 rods IMO.
    Probably cheaper also.
    "Electricity is really just organized lightning." George Carlin
    Derek
  5. #5
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Quote Originally Posted by jumper View Post
    I'm a little confused here. OP says basement walls are prebuilt (precast?) and setting on a gravel base... then says they will be using fiber-reinforced concrete. Exactly what is the fiber-reinforced concrete being used for? If basement slab floor, my understanding is it does not qualify as "foundation or footing".
    I will have achieved my life's goal if I die with a smile on my face.
  6. #6
    Join Date
    Jan 2009
    Posts
    14,191
    Quote Originally Posted by Smart $ View Post
    I dunno, I did not read real closely and thought there was a footer. Basement walls on a slab with no footer does not sound right.
    Yeah, slab does not count for an area for installing a CEE.
    I really only meant that a CEE is easier than rods to install IMO.
    Derek
  7. #7
    Join Date
    Dec 2010
    Posts
    1,505
    The problem I have is convincing the AHJ there is 20'. He can see two rods and assumes they are 8' long, but doesn't assume there is 20' of #4.
    I went to a meter pedestal a couple of weeks ago to install the service, and the inspector passed the install, even though the rods were only 9" apart. Don't know who built it...(just a side note)
  8. #8
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    He said walls set on gravel base, so I don't think they set on the floor slab. Not familiar with the design, but I'm thinking the gravel serves as a self-leveling "footing". Likely a typical floor slab.
    I gathered that and agree. I only commented because I don't see a yet-to-be-poured concrete foundation or footing in the OP description.
  9. #9
    Join Date
    Dec 2010
    Posts
    1,505
    Watched one being installed a couple of years ago. I don't see how it would last being set on gravel, but as usual, change frightens most.
    http://www.superiorwalls.com/pdf/Ene...n_Two_Days.pdf
  10. #10
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Quote Originally Posted by Hv&Lv View Post
    Thanks for the info link.
    Time will tell on it lasting...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
