Closed Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: Exothermic welding issues
  1. #1
    Join Date
    Jun 2005
    Delmarva, USA
    Posts
    1,549
    Today, I was able to install a couple of exothermic welds on a grounding grid for a new building.
    We have one of those graphite molds that fits over the top of the ground rod, and allows a #2 wire to pass-thru. The end weld forms a "T" ....
    I was having problems getting the starter powder to ignite (using a torch). I didn't have a flint striker handy. We finally got it going by "stirring" the starter powder with a scrap piece of wire while the torch flame was shooting into the side slot.
    I figure that I could use some July 4 sparklers the next time for better results....
  2. #2
    Join Date
    Jul 2005
    northern new jersey
    Posts
    194
    When you pour the powder into the mold do you get the fine starter powder out of the bottom of the charge tube? If you don't or you mix it into the charge you will have a hard time lighting it. Is it dry? I stop using the pour shot. I use the electric starter now. It keeps me from getting burned.
  3. #3
    Join Date
    Jul 2005
    northern new jersey
    Posts
    194
  4. #4
    Join Date
    Dec 2010
    Posts
    1,476
    Quote Originally Posted by kbsparky View Post
    As hot as that stuff gets, I would highly recommend a starter unit: http://www.erico.com/products/CADWEL...ntrol_Unit.asp
    I have a nice scar on my leg where that stuff burnt through at the bottom and spilled out. Amazing how fast you can get out of a pair of pants when you and them are on fire!
  5. #5
    Join Date
    Feb 2003
    Huntsville Alabama
    Posts
    1,802
    I wonder if ESTES rocket motor igniters would work?
    Some people are like slinkies. They serve absolutely no useful purpose. But still put a smile on your face when pushed down a flight of stairs.
  6. #6
    Join Date
    Jul 2005
    northern new jersey
    Posts
    194
    Quote Originally Posted by Hv&Lv View Post
    Sorry to hear about you getting hurt. I was doing a cell tower site one fall day and I overlooked all the leaves in the trench................
    Boy did that make a big fire!
    (sorry still don't know how to make the dunce head thing)
  7. #7
    Join Date
    Apr 2009
    Kansas
    Posts
    1,272
    Just place your cusor on top of the icon see how easy that was
    Heck if I can do it, I know the rest of you can.
    Electricity is Color Blind
    Leave the shirt pocket rules in your pocket.
  8. #8
    Join Date
    Dec 2011
    Ocala, Florida, USA
    Posts
    760
    It doesn't sound like you read the instructions about the fine powder in the bottom of the container. If you did, and still have a problem, I have experienced problems with an old batch that has gotten shaken up, or a tube that is left open to moisture. In that case, you can throw it away and try again, or you can use the powder from the bottom of another container. I discourage you from stirring the powder with a piece of wire. No matter how careful you are trying to be, I can smell disaster. As others have stated, do you have any idea of just how HOT that stuff is?
    I know what I don't know, and I know where to go to find it!
  9. #9
    Join Date
    Jun 2005
    Delmarva, USA
    Posts
    1,549
    Yes, I did read the directions, thank-you-very-much. Several times.
    This is why I was so frustrated in trying to get that dang thing to ignite.
    Maybe it was old -- sitting on the shelf at the supply house? I just bought the stuff the day before, so it was brand-new to me.
    I poured the metal powder mix into the mold very carefully. At the bottom, the starter power appeared to be embedded in the base. Directions said to re-cap the tube, and tap it to loosen, then pour 1/3 of it on top of the metal powder, and then the rest on the top of the mold after the top was set in place. I did exactly as directed. The stuff just would not get started, even with the MAPP gas flame directly on the pile of starter powder. Not until we stirred it with a piece of tie wire ....
    I got some July 4 sparklers today, so those should do the trick when we go back next week to complete the grounding grid in the foundation. I'll light the sparkler with the torch, and then stick the lit end into the top chamber ....
    The surprising part of the whole thing is the speed in which the exothermic process takes place. While I have read 15-20 seconds, that must include attempting to light the dang thing. Once lit, it's over in 1-2 seconds!
  10. #10
    Join Date
    Dec 2010
    Posts
    1,476
    I made some thermite "just for kicks" many years ago when I was working around a welding shop. Set it on a piece of 3/8 steel plate thinking we were going to see something cool. Once I got the Mag. strip started, the whole thing started burning, and burnt a hole in the 3/8 steel plate. It dripped onto the concrete floor below... You ever had a torch too close to concrete...
Closed Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
