Ansul System
crispysonofa
New England
Electrical and Security Contractor
Good Morning, I am wiring an ancillary system for a restaurant. This is my first time wiring one of these on my own and there is a gas valve on site that has me scratching my head a little bit. The valve has leads that are about 12'' long and it looks like a 3/8 connector would thread right onto it. Does anyone have any experience with these? I need to extend those leads to my ancil panel but I am not sure if I should just set a Jbox in close vicinity to the valve? I have posted the images online so you can have a look by following the links below. I really appreciate the insight.
https://ibb.co/ip7RKf
https://ibb.co/ch9Ozf
LarryFine
Henrico County, VA
Electrical Contractor
I have wired several dozen Ansul systems. A 1/2" flex connector will fit, some 3/8" flex connectors will also fit. So will a 1/2" EMT connector, but you don't want EMT here.
You will then need a short piece of flex to reach the nearest mounting surface (like a wall) to mount a junction box. I usually use a handy box and blank cover for the joints.
crispysonofa
New England
I got nervous from the literature of the valve and saw something that said explosion proof so I sought more information. I thought I might have needed some special type fitting but I thank you so much for the info I will set a J box near the valve.
infinity
New Jersey
Journeyman Electrician
Yes I did. Shows how familiar I am with this. I got it wrapped up today and tested everything is good I really appreciate the help and information you all have shared with me!!
I'm going to change the title of this thread for purpose of future searches.
LarryFine
Henrico County, VA
So, tell us your solution. A pic would be appreciated, so we can critic..., I mean, critique your work. :D
crispysonofa
New England
I will take a pic when I get back with inspector. My solution was to thread on a 1/2'' LFMC connector onto the valve and mount a Jbox (Raco 232) on the wall there. Came off the valve with a small whip of LFMC. I used LFMC because kitchens get nasty.
