Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: box accesability
  1. #1
    box accesability
    Looking for opinions on an install. Hard lid ceiling in a bathroom with two 2x4 fluorescent lights. CMU walls that extend all the way to the roof deck, basically leaving no access above the ceiling from inside or outside the room. Okay to set a box above the fixtures? I guess I am basically asking if a box is considered accessible if a fixture has to be totally removed from the ceiling to access it. Also, would it sway your opinion if the box feeds the lights? I feel the box would not be considered accessible, whether it is feeding the light or if it was just a pull box for a totally different circuit. Anyone else?
  2. #2
    Join Date
    Feb 2003
    Somewhere over the rainbow
    Posts
    3,279
    If i am understanding your question correctly then here is my comment:
    That is how most of the wiring is done. Isn't it? you pull the wire, install the box and the fixture goes over the box. Perfectly fine installation.
    Edward
    The only thing I know, is the progressive discovery of my ignorance
  3. #3
    I'm sorry, bad description. Standard 4 square mounted to some structural steel with a whip to the light.
  4. #4
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,444
    Quote Originally Posted by plumb bob View Post
    No. Not accessible.
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,929
    Boxes above the ceiling and adjacent to recessed florescent fixtures are fine IMO. They have been installed that way for as long as flourescent fixtures have been made.
    Rob
  6. #6
    Join Date
    Feb 2009
    Posts
    9,444
    The words "2x4 fluorescent lights" and "4 square mounted to some structural steel with a whip to the light" lead me to believe there is some distance between the box and the light.
  7. #7
    Join Date
    Apr 2009
    Olathe, Kansas 338 mi SE of Wingedhorses
    Posts
    2,726
    Quote Originally Posted by ActionDave View Post
    Just to play Devil's Advocate; The box is accessible once you remove the 2 X 4 luminare.
    Electricity is Color Blind
    Leave the shirt pocket rules in your pocket.
  8. #8
    Join Date
    Jul 2012
    Orlando
    Posts
    92
    Can you pipe directly into the fixture? Or does the box contain other circuits thus making the light a raceway?
  9. #9
    Join Date
    Feb 2009
    Posts
    9,444
    Quote Originally Posted by John120/240 View Post
    Sure, if there were an acess panel behind the light.
  10. #10
    Join Date
    Apr 2009
    Posts
    2,726
    From the OP I assumed that removeing the luminare gives you access to the space above
    example attic
Posting Permissions
  • You may not post replies
  • You may not edit your posts
