Results 1 to 6 of 6
Thread: lightning protection down conductor
  1. #1
    Join Date
    Aug 2012
    United States
    Posts
    1
    Can a bare copper lightning protection conductor be routed exposed in a return air plenum between the roof penetration and a PVC conduit routed from the ceiling to the grounding electrode below ground? Does this violate NEC 300.22C?
  2. #2
    Join Date
    Apr 2010
    Posts
    833
    Lightning protection conductors have a special cable construction................if you are under any jurisdiction you would have to use it.me thinks.
    dick
  3. #3
    Join Date
    Feb 2003
    Illinois
    Posts
    23,352
    I don't really like lightning protection conductors inside the building, but NFPA does permit them to be inside the building. There are rules that require any metal object within 6' to be bonded to the lightning protection conductor.
    The lightning protection conductors are normally bare and if that is the case I see no reason why they can't be installed in a 300.22(C) space.
    Don, Illinois
    Ego is the anesthesia that deadens the pain of stupidity. Dr. Rick Rigsby
    (All code citations are 2017 unless otherwise noted)
  4. #4
    Join Date
    Aug 2009
    inside Area 51
    Posts
    505
    Rob11,
    Is the bare copper conductor and the pvc piping rated AND labeled for
    this installation [ RE: Section 602.2.1.1 in the `06 IMC ] ?.....If not,
    then "no install" in the plenum.
  5. #5
    Join Date
    Jul 2007
    Virginia
    Posts
    957
    Quote Originally Posted by north star View Post
    Rob11,
    The bare copper is inside the duct and the PVC is the raceway external to the duct, 602.2.1.1 does not apply.
  6. #6
    Join Date
    Aug 2009
    inside Area 51
    Posts
    505
    "Can a bare copper lightning protection conductor be routed exposed in a return air plenum... "
    My bad!....Section 602.2.1.1 applies only to "combustible" electrical
    methods and materials........Gregg Harris is correct!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
