Hello, i am a homeowner and believe i had some shady electrical work done. I am looking for help with NEC / Sparks Nevada electrical codes.
Concerns:
1. Romex run to metal housing for can lights (round knock out, not rectangular tabs) with no barrier between knockout edge and romex
2. Older 2 wire outlets, have neutral and ground tied together to create impression if false ground when tested.
3. Electrical for bathroom fan and under floor heat dead end somewhere because general contractor forgot to install.
4. Electrical wires (switch) buried in drywall mud and then extended to proper location.
5. No access to some of above due to no access to attic in addition.
Any help that could be given would be appreciated.
Concerns:
