Results 1 to 5 of 5
Thread: Reversing single phase AC motor rotation direction.
  1. #1
    Join Date
    Sep 2012
    KSA/Riyadh.
    Posts
    23
    Dear All,
    Could anyone please tell me how to reverse the rotational direction of a single phase AC motor?
    Thank you in advance.
    Best regards.
  2. #2
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,812
    Quote Originally Posted by hisham1986 View Post
    Dear All,
    Best regards.
    More information on the type of motor is needed - some are designed to not be reversible - like say the necessary leads to switch were not made accessible to be able to switch them.
    First thing is knowing if it is an induction motor or wound rotor motor.
    If an induction motor there are several types, split phase, capacitor start, capacitor start - capacitor run all require reversing two leads to change polarity between main and aux windings, if the manufacturer does not bring all the leads to the termination box you may not be able to reverse it. Shaded pole motors need to have the rotor physically removed and turned 180 degrees to reverse rotation - this again can depend on the design of the motor if that is even possible to do.
  3. #3
    Join Date
    Feb 2006
    Lake of the Ozarks
    Posts
    2,875
    Reversing the polarity of the "Start" winding, in relationship to the "Run" winding, reverses the direction of rotation of all single-phase alternating current (AC) motors
    Those who can do, those who can't teach
  4. #4
    Join Date
    Sep 2012
    KSA/Riyadh.
    Posts
    23
    Quote Originally Posted by Rewire View Post
    Could you please elaborate more? am really thankful for your help and advise at the same time
  5. #5
    Join Date
    Feb 2006
    Lake of the Ozarks
    Posts
    2,875
    check out this video see if it helps
    http://www.youtube.com/watch?v=Mnz82...eature=related
Posting Permissions
  • You may not post replies
  • You may not edit your posts
