Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: rotor motor inertia.
  1. #1
    Join Date
    Feb 2012
    Bangalore,India
    Posts
    68
    the formula to calculate the rotor motor inertia for 3 phase induction motor. in kg-m2
  2. #2
    Join Date
    Aug 2004
    Northern illinois
    Posts
    15,827
    Quote Originally Posted by srinivasan View Post
    There is no special way to calculate motor rotor inertia. It is calculated the same way you would calculate the inertia of anything else. To do so you need to know the shape of the thing and its mass. Most of the time you can get this information from the manufacturer fairly easily.
    Bob
  3. #3
    Join Date
    Sep 2008
    UK
    Posts
    10,715
    I assume you mean motor rotor inertia rather than rotor motor inertia?
    As petersonra has stated, the rules are no different for this.
    The difficulty here it that it is a complex assembly with different materials and usually with some holes.
    Depends on how accurately you want it and for what purpose. For a quick and dirty approximation I'd take a solid steel cylinder the length and diameter of the rotor and the steel shaft, also as a cylinder and add the two together. This is likely to give you a worst case.
    FWIW, solid cylinder inertia is
    I = m*r2/2
    m being mass.
    m = pi(r2) * length * material density.
    The density of steel is around 7,800kgm-3
    I don't know what application you require this for.
    In most that I've dealt with where inertia calculations are required, the load inertia has greatly exceeded motor inertia when referred to either load or motor relative speed.
  4. #4
    Join Date
    Feb 2012
    Bangalore,India
    Posts
    68
    Quote Originally Posted by petersonra View Post
    my customer asking this information , and we are not a motor manufacture i can get simply from supplier. as a electrical person i need to know what is the thing. so only asked. any way thanks sir...
  5. #5
    Join Date
    Feb 2012
    Bangalore,India
    Posts
    68
    Quote Originally Posted by Besoeker View Post
    I assume you mean motor rotor inertia rather than rotor motor inertia?As petersonra has stated, the rules are no different for this.The difficulty here it that it is a complex assembly with different materials and usually with some holes.Depends on how accurately you want it and for what purpose. For a quick and dirty approximation I'd take a solid steel cylinder the length and diameter of the rotor and the steel shaft, also as a cylinder and add the two together. This is likely to give you a worst case. FWIW, solid cylinder inertia is I = m*r2/2m being mass.m = pi(r2) * length * material density.The density of steel is around 7,800kgm-3I don't know what application you require this for.In most that I've dealt with where inertia calculations are required, the load inertia has greatly exceeded motor inertia when referred to either load or motor relative speed.
    fd fan motor for incinerator package. my customer is asking this information.. better i can ask from supplier. but now i know something because of you. if any worst case i can apply this... thanks
  6. #6
    Join Date
    Sep 2008
    UK
    Posts
    10,715
    YW.
    We've put a number of variable speed drives on fans and, in my experience, the fan inertia far exceeds that of the motor.
  7. #7
    Join Date
    Jul 2006
    SE USA as far as you can go
    Posts
    2,562
    This data is typically provided by the supplier.
    The formula -
    H = 5.48E-9 * WR2 * RPM2 / MVA (When WR2 is in kg-m2)
    Total RPM
    The total RPM is equal to the Motor RPM.
    Total WR2
    The total WR2 is calculated based on the Total RPM and Total H using the equation above.
    Total H
    This is the arithmetic sum of the Motor, Coupling and Load H in MW-sec/MVA.
    "Just because you're paranoid, doesn't mean they're not out to get you"
  8. #8
    Join Date
    Sep 2008
    UK
    Posts
    10,715
    Quote Originally Posted by kingpb View Post
    The formula -
    Total RPM
    Total WR2
    Total H
    Inertia does not depend on rotational speed. See post #3.
    I = m*r2/2
    m being mass.
    No rpm required.
  9. #9
    Join Date
    Jul 2006
    Posts
    2,562
    I = m*r2/2
    m being mass.
    No rpm required.
    You'll notice that the formula is for H when inertia and RPM are known, or to calculate inertia when H and RPM are known.
    It does give the inertia when no other info is known.
    Sorry if it was misleading, maybe should have clarified better. ETAP uses this info to do motor starting dynamic analysis.
  10. #10
    Join Date
    Sep 2008
    UK
    Posts
    10,715
    You'll have to explain to me what H is a measure of.
    I've had to do a lot of dynamic analysis to determine machine and drive ratings for various projects we have undertaken.
    But H is new to me.
    In simple terms what is it?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
