vidividi12
- San Marino
- Electrician
I am trying to find a coaxial surge protectors that is maching items below. I found Erico surge protectors (https://m.erico.com/category.html?category=R1408&country=us&language=en ) but it's datasheet doesn't have all below specs. Which model is that I need?
-Providing surge protectors with operating temperature from minus 40 deg C to plus 100 deg C.
-Protectors shall be bi-directional with no signal loss.
-Provide in-line protectors.
-Moisture Resistance: MIL-STD-202.
-Maximum Power at 50 Ohms: 500 watts.
-Breakdown Voltage at 100 Volts per Second: 200-300 Volts.
-Residual Voltage at 1 kVolt (U.S.): Less than 600 volts.
-Power Handling: 10kA at 10 shocks, and 20kA at 1 shock.
-Return Loss for N Connectors at 1 GHz: Less than minus 25 dB.
-Insertion Loss for N Connectors at 1 GHz: Less than 0.03 dB.
-Housing: Copper alloy with CuZnSn finish.
-Insulation: Teflon per ASTM D-170.
-Contact Shocks: Gold plated copper alloy or beryllium copper.
