Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Smoke detector Location
  1. #1
    I have a project in which we are installing smoke detectors in apartments that have a vaulted ceiling. My question is we now have them installed above the doorway for the room. This leaves alot of wall space above to the vault. My question is do they need to be all the way at the top on the vaulted ceiling. IF so is there an exception for access to turn off or difficulty in changing battery?
  2. #2
    Join Date
    Feb 2003
    Somewhere over the rainbow
    Posts
    3,279
    You can probably get the instruction from the manufacturer's website.
    Edward
    The only thing I know, is the progressive discovery of my ignorance
  3. #3
    Join Date
    Jul 2007
    Iowegia
    Posts
    17,836
    Local building/fire codes will dictate their locations. Placement is not an NEC issue.
  4. #4
    Join Date
    Dec 2004
    Windsor, CO NEC: 2017
    Posts
    16,193
    Check out this post:
    http://forums.mikeholt.com/showthrea...514#post649514
    Also, the FAQ sticky thread here in the NEC forum has a similar post.
  5. #5
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,021
    I believe they will need to be placed at the highest point in the ceiling within 6 or so inches from the peak.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  6. #6
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,021
    The firex brochure I have states to install the smoke detector within 3' of the peak of a vaulted ceiling
  7. #7
    Join Date
    Jan 2004
    Maryland
    Posts
    315
    Smoke alarms mounted above a door will not be effective until the smoke has built down to there level. This will reduce the effectiveness, sometimes greatly based on the slope of the ceiling. There is no exemption from placement due to ease of access to allow them to be placed lower.
  8. #8
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    14,191
    The NEC only covers the wiring between the devices. The IRC/IBC and NFPA 72 mandates the placement and type of devices.
    "Electricity is really just organized lightning." George Carlin
    Derek
  9. #9
    Join Date
    Mar 2006
    SW Florida
    Posts
    2,558
    Within 3' of the highest point of the ceiling.
    Unlimited Electric Contractor/Standard Electric Inspector/Traffic Signal Inspector/Highway Lighting and Level One Traffic Signal Installer.
    I know you believe that you understand what you think I said but I'm sure you realize that what you heard is not what I meant.
  10. #10
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    36,318
    Quote Originally Posted by Cavie View Post
    So does that mean if the max height of the vaulted ceiling is less than three feet above the current location it is still acceptable?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
