Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: 4-20 MA transmitter signal
  1. #1
    Join Date
    Feb 2012
    Bangalore,India
    Posts
    68
    Field tranmitter has 4-20 ma output which is connected to plc. plc output supply to transmitter is 24Vdc. but in field transmitter side receives only 16.5 Vdc. What will be the causes for voltage drop.
  2. #2
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    6,779
    130525-1508 EDT
    Loop resistance of the wire.
  3. #3
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Could also be 250 ohm series resistor in the loop. An older method, but sometimes local indicators with 1-5Vdc input are used in conjunction with the transmitter. The resistor creates a 1-5Vdc drop across it for input to the indicator.
    I will have achieved my life's goal if I die with a smile on my face.
  4. #4
    Join Date
    Feb 2012
    Bangalore,India
    Posts
    68
    Quote Originally Posted by Smart $ View Post
    yeah, used model is 3051 cg rosemount pressure transmitter with local indicator. my question is, if 16.5 voltage only occurs across the transmitters. will transmitter work properly. what are the test we have to do for transmitter working condition
  5. #5
    Join Date
    Feb 2012
    United States
    Posts
    605
    put ammeter in series with 4-20ma line and measure it over full range?
    just scale the plc input to match?
    4-20ma circuits often have scaling adjustments called span & elevation or similar names.
  6. #6
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    6,779
    139526-0739 EDT
    srinivasan:
    Look on the transmitter data sheet for the minimum voltage across the transmitter. The purpose of the current loop is to allow accurate data measurement over wire loops with varying resistance. The transmitter is a constant current source down to some minimum voltage across the transmitter.
    Experimentally adjust the transmitter to produce a 20 mA load. Increase the series resistance until the transmitter can not maintain a 20 mA load. Measure the voltage across the transmitter. That is your minimum transmitter voltage. Add some voltage to this as a safety factor.
  7. #7
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Quote Originally Posted by srinivasan View Post
    Here's what the manual states...
    Power Supply for 4-20 mA HART
    Transmitter operates on 10.5 - 42.4 Vdc. The dc power supply should provide
    power with less than two percent ripple.
    NOTE
    A minimum loop resistance of 250 ohms is required to communicate with a
    Field Communicator. If a single power supply is used to power more than one
    3051 transmitter, the power supply used, and circuitry common to the
    transmitters, should not have more than 20 ohms of impedance at 1200 Hz.
    Figure 2-19. Load Limitation
    Maximum Loop Resistance = 43.5 * (Power Supply Voltage 10.5)
    The Field Communicator requires a minimum loop resistance of 250Ω for communication
    The total resistance load is the sum of the resistance of the signal leads and
    the load resistance of the controller, indicator, and related pieces. Note that
    the resistance of intrinsic safety barriers, if used, must be included.
    If this is a new installation, recommed going through the entire commissioning and calibration procedure, Sections 3 and 4. Link to manual...
    http://www2.emersonprocess.com/sitea...-0100-4001.pdf
  8. #8
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Quote Originally Posted by mike_kilroy View Post
    While that may work, that's not the proper way to do it, and should only be used as a last resort remedy to keep things running.
  9. #9
    Join Date
    Feb 2012
    Bangalore,India
    Posts
    68
    if wire sizing is not proper. what will be the effect. for 24 v dc and 4-20 ma, our selected cable size is 1.5 sq.mm and 2 core. is it reason for voltage drop
  10. #10
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    6,779
    130526-0829 EDT
    srinivasan:
    If your open circuit voltage is a regulated 24 VDC, and there is a 5 V drop at 20 mA in the receiver, then your wire loop resistance drop is only 24 - 5 - 16.5 = 2.5 V. That is not much drop for the wiring. Find out the minimum voltage that the transmitter will operate at over its full range. In other words at 20 mA.
    Pay attention to Smart $'s information.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
