Originally Posted by
templdl
...If you believe as strongly as you do, start doing something about it or quit complaining. Get involved with the appropriate code council with documentation that back you opinion.
Without the backing of hundreds of thousands of dollars for research, the CMP will never accept proposals to limit the use of AFCIs. They are here to stay. The best I could hope for is that the UL standard for AFCIs be revised to require a GFP function in all AFCIs as it appears to me that the GFP function it the most common trip.
After reading the UL report that I posted in the first post of this thread, I am very confused as to how UL tests AFCIs with "arcing faults". The more I read about this, the less I believe that an arcing fault with enough energy to start a fire is even possible at dwelling unit voltages.
Don, Illinois
Ego is the anesthesia that deadens the pain of stupidity. Dr. Rick Rigsby
(All code citations are 2017 unless otherwise noted)
Bookmarks
