NMB with Isolated ground ?
ritelec
Jersey
Do they make 12-2 or 14-2 nm-b with an isolated ground (2 grounds), and if so, what would it be called?
Thank you.
Rich
augie47
Tennessee
around here it's call 12/3 W/G (or 14/3 W/G) with the red re-identified :D
ritelec
Jersey
Thanks augie47........
yeah, tape the red green (or srtip it and save on the tape),,, but would that be code?
Probably not.
Do they make nm with 2 grounds?
Or would you have to go with mc with the sheath being rated for ground?
Or is taping the red code compliant?
augie47
Tennessee
Thank you augie47.
I will be taking that as a no!
Thou shalt not tape the red wire green.
:thumbsup:
Perhaps I misread it.. I do that a lo....t, but, as long as it's part of a cbale assembly, it seems to me you can tape it.. the catch might be the "where conditions of maintenance ensure,,,,," partm
hillbilly1
North Georgia mountains
Owner/electrical contractor
I havn't looked it up in a while, but didn't they change that a couple of code cycles ago, where the tape was not acceptable on switch legs and such, that it had to be heatshrink or permanant marker to re-identify?
don_resqcapt19
Illinois
retired electrician
Assuming that the circuit originates at the service equipment and the box at the load end is non-metallic, there is no need for an "isolated" ground. The normal installation with NM that orginates at the service equipment and it terminated in non-metallic boxes provides the same benefit at an isolated ground circuit.
jumper
Yep. IGs in standard resi is a joke.
svh19044
Philly Suburbs
...not if you have hifi/audiophile customers. Then again, nothing standard about them.
texie
Fort Collins, Colorado
I recently did one in a commercial bldg. that was about 3 sub panels away from the service. Tried to gently explain to the specifier that it was useless to feed it from the sub panel unless we had a separate insulated ground back to the service. They didn't want to hear it. See this a lot.
