Results 1 to 6 of 6
Thread: Mounting to 3 1/2" O.D. tubular steel framing
  1. #1
    Join Date
    Nov 2003
    The incredible, yet very expensive, Hudson Valley, NY NEC 2008
    Posts
    1,842
    Customer put up a 110' by 70' "temporary" building. The roof and sides are basically a huge single piece tarp.
    I need to wire and install some lighting. I'm considering mounting wood to the 3 1/2" tubular steel framing with U-bolts, then mounting wallpacks to the wood.
    Never encountered a job like this before.
    Any thoughts or suggestions.
    Mike, Dutchess County, NY
  2. #2
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,462
    Quote Originally Posted by mjf View Post
    ..... I'm considering mounting wood to the 3 1/2" tubular steel framing with U-bolts, then mounting wallpacks to the wood.
    I would use unisrtut instead of wood.
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
  3. #3
    Join Date
    Nov 2003
    Posts
    1,842
    Quote Originally Posted by ActionDave View Post
    Thanks....brain freeze!
  4. #4
    Join Date
    Jul 2005
    Gainesville, Florida
    Posts
    1,052
    I've got kind of the same thing on the table. It is an enclosed insulated steel garage. I was going to use steel track and studs to mount my EMT on. Span the structural steel frame with some track and tek screw it all together with one hole straps on the EMT. Not as heavy as the unistrut nor as costly. Mine is covered though with corrugated steel sheet, not a tarp.
  5. #5
    Join Date
    Oct 2013
    texas, USA
    Posts
    6
    Yes, I think this is the best answer for your question and think will do the work.
  6. #6
    Join Date
    Apr 2007
    Huntington Beach, CA (19 Hrs. 22 Min. from Winged Horses)
    Posts
    6,501
    if the tube frame is 3 1/2" od, that is the same as 3" GRC.
    so i'd use strut straps and 1 5/8" strut to attach to the
    frame, then bolt whatever to the back of the strut.
    say two 1' long pieces of strut per wall pack, with nuts
    and bolts holding the pack to the backside of the strut.
    ~New signature under construction.~
    ~~~~Please excuse the mess.~~~~
Posting Permissions
  • You may not post replies
  • You may not edit your posts
