Results 1 to 9 of 9
Thread: T8 Retrofits
  1. #1
    Join Date
    Apr 2012
    NY
    Posts
    180
    T8 Retrofits
    Does anyone know if a source for a retrofit kit for a 4' 4 bulb fixture? I'm looking for something to retrofit lay in troffers but everything I find includes a reflector, which is unnecessary.
  2. #2
    Join Date
    Sep 2005
    western suburbs, chicago
    Posts
    138
    I believe that you need only to replace the ballast.
  3. #3
    Join Date
    Oct 2013
    Posts
    5
    Usually we.replace a 4 banger with a 2 banger including a reflector.
  4. #4
    Join Date
    Jun 2005
    Delmarva, USA
    Posts
    1,645
    Most of the time, all you need is a new ballast.
    Check the label on the ballast, to see if you need "shunted" sockets. If so, then be sure to wire-nut both sides of each socket to the new leads to emulate shunted sockets. The original sockets that are used for T-12 bulbs can be used with the T-8 bulbs if they are in good physical condition, since the spacing of the pins on the tubes are the same.
  5. #5
    Join Date
    Apr 2006
    Upstate S.C.
    Posts
    802
    Quote Originally Posted by kbsparky View Post
    Pardon my ignorance, but what is a "shunted" socket?
    RC
    It's my name going on that drawing, not yours. If what you want ain't right, it ain't going on the drawings!
  6. #6
    Join Date
    Apr 2006
    Upstate S.C.
    Posts
    802
    Quote Originally Posted by sparky999 View Post
    This likely is the way to go. It's also a good time to move to T5's. You might want to take some light meter readings on the existing fixtures and run some calcs on what you really need. You then can make a decision to move to T5's, regular or HO.
    For anything other than residential, I have moved to T5HO, either with a step ballast or a dimming ballast (preferred). You can get fixture efficiencies over 90% now!
    RC
  7. #7
    Join Date
    Jun 2005
    Delmarva, USA
    Posts
    1,645
    Quote Originally Posted by Ragin Cajun View Post
    RC
    Shunted means that both contacts in the socket are electrically connected. Many electronic ballasts for T-8 bulbs require the sockets to be shunted or both pins to be connected to the single lead that terminates there.
  8. #8
    Join Date
    Jun 2011
    Oregon
    Posts
    176
    RC
    In all fairness, T8 is more energy efficient, less expensive, and more reliable.
    I've used a lot of reflector kits. Some of them from, say, US Energy Sciences, will send bits and pieces fairly inexpensively. You'll have to put the kits together which isn't very time consuming. Other companies, like TCP or Optimum, will include the ballast already pre-wired to sockets and new socket bars. I'm usually a fan of new fixtures, especially if the rebates are good. But kits can work wonders if the existing fixtures are still in alright condition.
    I know lots about lightbulbs!
  9. #9
    Join Date
    Mar 2009
    Norman, OK, USA
    Posts
    69
    Quote Originally Posted by TNBaer View Post
    In all fairness, T8 is more energy efficient, less expensive, and more reliable...
    This has been my experience as well. The higher cost of the T5's is often reason enough to stick with T8's, especially for retrofits where you are not necessarily able to reduce overall fixture count.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
