User Tag List
Results 1 to 6 of 6
Thread: What does vapor proof mean when discussing light fittings.
  1. #1
    Join Date
    Dec 2013
    Ireland
    Posts
    4
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Greetings from Ireland.
    I have just passed the aee.org CEM exams and have my first relamping project.
    I am a Chartered Engineer and have been a PE in Canada.
    I am familiar with IP ratings as well as many of the different codes
    I have read most of the posts here on Haz environments so have a grasp of the Classes/Divisions/Groups
    The specs I am getting for the replacement luminaries say the fittings are say, IP 66 vapor proof.
    My question is:
    Is there a vapor proof spec somewhere?
    Or am I missing something?
    Thanks.
  2. #2
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Vapor proof means sealed.
    Check out the images at this google link https://www.google.com/search?q=vapo...w=1024&bih=672
  3. #3
    Join Date
    Dec 2013
    Ireland
    Posts
    4
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks.
    Are they sealed to any standard?
    For example if the client asks 'how well' are they sealed I can hardly 'duck' the question?
  4. #4
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,846
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Carlow52 View Post
    Thanks.
    This link suggests that IP designations are defined in a European standard, but I have not idea how you would get a copy. I also do not see a mention of vapor proof in the short reference to IP 66.
    A common language synonym would be hermetically sealed or gas tight. But without a specification of the pressure it would have to withstand, it is not a complete definition.
    For large molecular weight substances composing the vapor, the seal would not have to be as perfect as for low molecular weight (small) gas molecules.
  5. #5
    Join Date
    Dec 2013
    Ireland
    Posts
    4
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    GD: You have hit the nail on the head here with the IP reference.
    This is exactly my dilemma and hence this post.
    I have luminaries rated as IP 54 up to IP 68 all of which are 'vapor proof'.
    Some are well made in Germany with good seals with quality O rings.
    Others are less well made around 100 degrees East
  6. #6
    Join Date
    Dec 2013
    Ireland
    Posts
    4
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just to add that I got the following information elsewhere:
    A vapour proof fitting corresponds to a sealed fitting rated to minimum IP65 and corrosion proof.
    There is a process where the words vapor proof are being discontinued in the literature.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
