Results 1 to 5 of 5
Thread: new change
  1. #1
    Join Date
    May 2014
    AZ
    Posts
    2,321
    new change
    ART-100 definitions.
    my suggestions for a proposal is:
    change
    Branch Circuit, Individual. A branch circuit that supplies
    only one utilization equipment.
    to
    only one utilization equipment using a single Outlet.
    outlet in italics because that word is a art-100 definition.
    why you ask, because the change rectifies a few issues around the intended use of a indi-bc, and, it helps align with "dedicated" from IBC and other published docs, etc.
  2. #2
    Join Date
    Mar 2014
    Utopia
    Posts
    1,367
    Quote Originally Posted by FionaZuppa View Post
    change
    to
    Well....Here is what you got for 2017 Edition. If you are suggesting any changes beyond that then I am sure the CMP 2 will be eagerly awaiting your public input and detailed substantiation for the 2020 Cycle.
    Branch Circuit. The circuit conductors between the final over-current device protecting the circuit and the outlet(s).
    (CMP-2)
  3. #3
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    18,968
    Quote Originally Posted by MasterTheNEC View Post
    The OP was talking about individual branch circuits.
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
  4. #4
    Join Date
    Mar 2014
    Utopia
    Posts
    1,367
    Quote Originally Posted by charlie b View Post
    2017 Language - Branch Circuit, Individual. A branch circuit that supplies only one utilization equipment.
    Again I am sure CMP 2 eagerly awaits the public input.
    Ah....ignore me Fella.....I see he used the latest version. I was worried many do not have the 2017 Yet. However, I see it did not change...My Bad.
  5. #5
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    14,195
    Yep.
    I did check out of curiousity, no change in definition for individual branch circuit for 2017.
    "Electricity is really just organized lightning." George Carlin
    Derek
Posting Permissions
  • You may not post replies
  • You may not edit your posts
