Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
Thread: 2017 NEC Pdf is available
  1. #21
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Quote Originally Posted by Sierrasparky View Post
    Ok Then what would it be!
    What would what be?
    I will have achieved my life's goal if I die with a smile on my face.
  2. #22
    Join Date
    Feb 2007
    USA
    Posts
    5,544
    I thought the NEC was not a design guide!
    Quote Originally Posted by rbalex View Post
    It depends somewhat on the CMP. CMP14 was heavy into using Section 90.1(C). Those CMPs that are especially heavy into residential or light commercial are more likely to give design directives. A few unnamed aren't quite sure.
    Yes I would have to agree with you.
    The more and more the CMP's tweak and twiddle the more complex and the more confusing their clarifications get.
    I pointed out the code is not intended to be a design guide "
    (C) Intention. This Code is not intended as a design
    specification or an instruction manual for untrained persons.
    Well darn if it does not look like one.
  3. #23
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Quote Originally Posted by Dennis Alwon View Post
    I understand that you can't do it even under the 2014 but I was wondering if they were trying to clarify it...Did a great job of it if that was their intent.
    As best I can tell, the intent was to include any work surface similar to a countertop. The term countertop is not defined in the NEC and the definition varies in dictionaries.
  4. #24
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,921
    I ordered the 2017 NEC book with the pdf from Nfpa.org. I got an email that the pdf is available for download. I just downloaded it-- simple easy. Just thought you would all like to know
    How much is it?
    Rob
  5. #25
    Join Date
    Feb 2007
    USA
    Posts
    5,544
    Quote Originally Posted by Smart $ View Post
    What would what be?
    That 3 foot space be. How would it be counted or used as far as receptacles
  6. #26
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    It would be a 3' wall space. Being more than 2' wide, at least one receptacle is required within that space to satisfy 210.52(A).
  7. #27
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    32,979
    Quote Originally Posted by infinity View Post
    How much is it?
    The pdf and softcover is almost $200 after tax and all. Book and pdf are $95 each
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  8. #28
    Join Date
    Mar 2003
    Vermont
    Posts
    1,308
    I'm looking for 2 handbooks and a pdf , need a link if you've one Dennis
    ~RJ~
  9. #29
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    32,979
    NFPA.ord They have a special where you get the tabs for free--- http://catalog.nfpa.org/NFPA-70-Nati...aspx?icid=D682
    Seems like you wuill have to go to this page and then choose products by topic
  10. #30
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Free tabs not advertised on multi-product page:
    http://catalog.nfpa.org/NFPA-70-Nati...aspx?icid=B484
Posting Permissions
  • You may not post replies
  • You may not edit your posts
