Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: Lighting a Family Room
  1. #11
    Join Date
    Jun 2010
    Posts
    1,928
    Quote Originally Posted by kwired View Post
    This is a job for a lighting design specialist.
    Some installers are maybe closer to being called that then others though.
    This leans towards the somewhat artistic side of lighting design given that its easier to describe this part with words and visuals than numbers.
    Quote Originally Posted by mgookin View Post
    And you better have really good carpenters, lumber and drywall crew because that's going to light up every imperfection. We call it "lamping the walls" in high end construction where you temporarily put a light source right against a wall or ceiling surface to mark imperfections for the trades to correct their minor imperfections.
    I've never been a fan of track lighting but for this application I think I'd see what's out there that might fit the room.
    The hardness of light source has a lot to do with this. Hard light such as sunlight on a clear day brings out surface imperfections much better than diffused light such as sunlight on overcast day. A light meter is not an imaging sensor. You could point it towards a window and it couldn't tell a normal glazing from a privacy glass.
    Clear lamps like MR16 halogen is 'harder' than a BR reflector lamp. The level of hardness depends on how well is diffused. I am not sure what unit is used to measure this and it is not part of lamp specs, so it is kind of trial and error. It wouldn't show up on a light meter reading, but it will show up on a photographic image. Optical pieces such as lens, diffusers, and textured reflectors consume some lumens as well as directionality which costs lumens per watt as well as target efficiency rating.
    The strange, multi-edged shadows you may see at gas station is a characteristic of LED lighting system that do not use a frosted diffuser to avoid optical losses.
    CRI, vertical and horizontal plane foot candles and conventional lighting design address this descriptively like I am, but I don't know what measurements are used.
    The diffuser, and to smaller extent, the texture of reflective coating and the design of the solid state fluorescent lamp element plays a role.
  2. #12
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,246
    The following pic is a rather humorous however real depiction of what can happen when lights are haphazardly applied to a ceiling:
    http://www.someecards.com/news/so-th...ok-like-boobs/
    With soffit lighting, if you dont run the light source from wall to wall, or within inches of it, you WILL have dark spots, and the customer WILL complain.
    We almost always let the customer spec lights. If they arent happy with the light, the shape of the fixture, the color, etc, it's on them. We can relamp, change dimmer settings, adjust height if a pendant, but it about kills me to just get a new fixture up, wipe off the fingerprints, and the customer goes "that's satin nickel...I thought I ordered brushed nickel...that looks hideous, take it down".
    If your customers are like that, do what kwired suggested: get a lighting specialist.
  3. #13
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    3,961
    For recessed lighting in vaulted ceilings I use Juno IC928 or IC926 slope cans. The LED variant will run you about $260/ea, and the incandescent $60/ea. The trims for both are another $40/ea. I won't even offer the option of regular recessed fixtures. That's what everyone does around here and it looks terrible. You can order the LED model in various color temps also.
    I've also installed LED tape behind the crown on the gable walls and that is a nice effect, but gives you no floor lighting.
    I just roughed in a cabin for a buddy last weekend with an exposed beam vaulted ceiling, and we are going to install track lighting where the ceiling meets the wall on both sides end-to-end and switched receptacles for floor lamps. There is also a beam running across the middle of the room, and I'm going to put a track across that. It's to highlight the exposed beams though; I couldn't imagine why you would want to highlight a drywall ceiling.
    My suggestion to them would be to use sloped cans, and do the LED behind some crown on the gable walls like I mentioned earlier and that would give them enough of an ambient effect on the vault.
    On the tape, look at Nova Flex LED, and specifically the variable temperature with a dimmable driver. It really helps set the mood for time of day. I've got some going up in a week or so in a double-tray ceiling. If I can remember I'll come back and post a short video here showing you what it is.
    Here is a pic of that tray ceiling. Those will be 18w LED recessed. We just put some IC926 LED cans in also in a vaulted ceiling. I'll try to get you a pic of those as well.
    Brought to you by Carl's Jr.
  4. #14
    Join Date
    Dec 2012
    Fort Myers, FL
    Posts
    4,013
    Quote Originally Posted by brantmacga View Post
    Buddy of mine did a 3 story addition at his house; on the 2nd floor he has barrel vaulted ceilings with Venetian plaster and that same molding setup you are showing with indirect lighting. It is incredible. The dimmers had extra wow to the ambiance.
    You make the lights come on and we make them go off.
  5. #15
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    3,961
    It's definitely one of my favorite effects. Years ago i would do it with rope lighting or fluorescent. Now with the variable temp LED's, you can dial in the exact color you're looking for. A friend of mine did a job with color changing LED cove lighting and color changing LED recessed lamps, but it really looked silly. That's what their customer wanted though.
  6. #16
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,130
    Color changing as in cycling by itself? That does sound horrible.
  7. #17
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    36,178
    Quote Originally Posted by GoldDigger View Post
    Was in Best Buy recently and noticed those, can't remember the name/brand.
    I also used the restroom and noticed that in a store that is dedicated to selling technology they did not have a single automatic flush valve, sink faucet, towel dispenser, or hand dryer. They must not sell those items and aren't that interested in them
  8. #18
    Join Date
    Dec 2012
    Fort Myers, FL
    Posts
    4,013
    Color changing in outdoor spaces when they change v e r y slow can be tasteful. Indoors I can't imagine it.
  9. #19
    Join Date
    Aug 2007
    Yachats Oregon
    Posts
    567
    Unless your in Vegas!
  10. #20
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    3,961
    Here is that ceiling finished...... its variable temperature LED, and you manually adjust via a wall controller to the temp you want; soft white or bright white.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
