Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: AL vs CU cost analysis
  1. #11
    Join Date
    Jul 2003
    New Jersey
    Posts
    25,380
    Quote Originally Posted by thekeymurphy View Post
    Interesting. I've recently switched to CU myself.
    Do they use much aluminum in the UK?
    Rob
  2. #12
    Join Date
    Jul 2005
    Posts
    819
    Quote Originally Posted by mstrlucky74 View Post
    Sorry should've been more clear. Scenario I'm referring to is when you have EMT and thhn copper conductors and want to switch to aluminum conductors. I often see a lot of value engineering requests for this.
    I only give back the savings of materials on these if it's my voluntary alternate.
    If it is requested, I will look at the labor, and maybe offer some of the savings back
  3. #13
    Join Date
    Sep 2008
    UK
    Posts
    11,591
    Quote Originally Posted by infinity View Post
    Aluminium but let that pass..................
    The answer is no. For control panel wiring, VFDs, installations, etc. I can't say it is never used but I don't recall any instances of it.
    The only places I've seen Al conductors used was the bus bars on high current rectifiers. I mean suites of 10kA and upwards.
    And on extruded heat sinks for power semiconductors.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
