Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: LEDs flashing in new house
  1. #1
    Join Date
    Jul 2015
    sangamon county, IL
    Posts
    31
    our new house was recently finished. They used incandescent recessed cans for lighting in the living room, but fitted them with halo drop in LED retrofits. I'm not normally much ova fan of LEDs, but these have great color and put off nice, evenly distributed light. Only one complaint. The ceiling fan and recessed LEDs are on the same circuit. Whenever the LEDs are on and you turn them off, then the fan, the LEDs flash. This only happens when you just turn the leds off, while the internal capacitors have some charge. I've never seen this with standard screw in LED bulbs, could it be an inductive kick of sorts from the fan turning off?
    get merc'd.
  2. #2
    Join Date
    Apr 2008
    Ann Arbor, Michigan
    Posts
    6,574
    161106-1724 EST
    Your post lacks consistency reread and correct it. I can not make logic sense from it.
  3. #3
    Join Date
    Dec 2012
    Fort Myers, FL
    Posts
    4,013
    Do they light for just a couple seconds and fade to zero?
    You make the lights come on and we make them go off.
  4. #4
    Join Date
    Jul 2015
    sangamon county, IL
    Posts
    31
    It's just a quick flash. I'll try to video it and get it linked here to explain it better.
    get merc'd.
  5. #5
    Join Date
    Jun 2010
    Posts
    1,928
    Quote Originally Posted by Solanaceae View Post
    How bright of a flash?
    Can you duplicate it with the fan off the whole time?
    The running and break down voltage of LED are almost the same and LEDs can make detectable amounts of light at micro amp levels. I've seen fade-then flash upon turn off too caused by the way the LED ballast was designed.
  6. #6
    Join Date
    Dec 2012
    Fort Myers, FL
    Posts
    4,013
    If you can get it in all one shot, show us the sequencing and timing of turning the switches off and the lights doing what they do.
    I'm thinking the fan motor is generating the power that's lighting the lights.
  7. #7
    Join Date
    Dec 2010
    Posts
    1,352
    Quote Originally Posted by mgookin View Post
    Free energy?
  8. #8
    Join Date
    Dec 2012
    Fort Myers, FL
    Posts
    4,013
    Quote Originally Posted by dkidd View Post
    Free energy?
    No because you had to pay to get it up to speed.
    Now if you had 12 cats on a seesaw...
  9. #9
    Join Date
    Apr 2008
    SW Florida
    Posts
    544
    or the cat / buttered bread, infinite power generator (I think I saw it here in the past)
  10. #10
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    4,605
    Quote Originally Posted by cpinetree View Post
    Cat-bread generator is too problematic; butter gets slung from armature, or the cat-rotor dies, thus creating a division by zero and an artificial black hole. Even attaching the cat to the shaft in the manner shown is likely to have grave consequences.
    Do ceiling fans act as generators when shut off but still spinning? Apparently so, enough miniscule amount of power comes from them to light up the LEDs for a pulse.
    A video of what you are describing would be most helpful.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
