Results 1 to 8 of 8
Thread: O&G - Electric Heat Trace for remote pipeline valve station
  1. #1
    Join Date
    Jun 2014
    Denver
    Posts
    23
    I need to provide freeze protection at a few remote oil pipeline valve stations. These would be at above-grade pig launcher/receivers and tie-in locations where we have drain valves. No utility power is readily available or cost-effective to bring into the area, we are in NE Colorado where we can experience cold snaps that last 2-5 days at or below -0degF, and will experience freezing issues if we don't apply some sort of heat trace freeze protection.
    Has anyone designed for a similar installation? We have a vendor pushing us hard on their solar-powered, dc heat trace packaged system, but I'm concerned of it's serial number of 0001. Has anyone else utilized DC heat trace? Experience with it?
    I know this can't be a unique situation and would really appreciate some feedback, tips/tricks, outside the box thinking, etc.
    Thanks in advance!
    ~T
  2. #2
    Join Date
    Sep 2016
    Longmont, CO
    Posts
    176
    Quote Originally Posted by csc_wyo View Post
    Thanks in advance!
    ~T
    Doesn't seem like you have a lot of choices!
    Is the DC system rated at least CID2?
  3. #3
    Join Date
    Jan 2017
    North Dakota USA
    Posts
    62
    Maybe look at McMaster Carr. They have all kind of heat trace, including dc.
    https://www.mcmaster.com/#heat-trace/=15ygsk5
    i have installed a few of theirs with the termination kits and the indicator lights at a local anhydrous plant we regularly work at, and it seems to work great. My installs were AC. I see their DC selection are 12, 24, and 36V. Their shipping has always been fast for us, but I'm not sure where they ship from either.
  4. #4
    Join Date
    Jun 2014
    Denver
    Posts
    23
    Quote Originally Posted by Jim1959 View Post
    Story of my life!
    All components will be CID2 rated. But unfortunately, I'm looking at Serial No. 00001 and I'm back to my first answer to you.
  5. #5
    Join Date
    Jun 2014
    Denver
    Posts
    23
    Quote Originally Posted by Dr Duke View Post
    Never a big fan of installations design out of Grainger or McMaster, but they've saved my hide before when I've been in a pinch. I did look at your link and they're limited to 3w/ft with their DC product. That may be good for some smaller installations, but doesn't provide the necessary heat for freeze protection with our type of system. Thanks for your input though, Dr. Duke!
  6. #6
    Join Date
    Oct 2007
    New Jersey
    Posts
    5,015
    If gas is available you might try looking for a skid-mounted steam generator and heat trace with steam. Couple of control circuits and an isolated steam shed and you're in business. Worked like a charm at a nitroglycerin plant I worked in many years ago.
  7. #7
    Join Date
    Apr 2007
    Colorado
    Posts
    154
    Sounds more like an operational issue than an electrical issue. Consider: after receiving, drain the receiver. When going back to normal operation, flow around the receiver, not through it. Residual oil will settle into valve, but water should already be drained at that point. Maybe your design drawings assumed heat trace was needed but no one in engineering discussed with operations staff.
  8. #8
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    ... I did look at your link and they're limited to 3w/ft with their DC product. That may be good for some smaller installations, but doesn't provide the necessary heat for freeze protection with our type of system. ...
    What Watt density do you need?
    2 runs @ 3W/ft = 6W/ft
    I will have achieved my life's goal if I die with a smile on my face.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
