View Poll Results: Please select all complaints you have received about resident LED work
Voters
19. You may not vote on this poll
  • Dimming - does not dim smoothly across entire range
    7 36.84%
  • Dimming - does not turn on at lowest setting
    6 31.58%
  • Dimming - shimmer, flicker, and such despite using proper dimmer
    10 52.63%
  • Dimming - excess ballast buzz when dimmed
    6 31.58%
  • Dimming - color doesn't mimic incandescent closely enough
    3 15.79%
  • Buzzing ballast - without dimming
    1 5.26%
  • Light color uneven between fixtures
    1 5.26%
  • Just don't like the color
    6 31.58%
  • something else
    4 21.05%
  • NEVER had LED complaints
    4 21.05%
Multiple Choice Poll.
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Thread: Residential LED installs, client concerns
  1. #11
    Join Date
    Jun 2010
    Posts
    1,928
    I've always figured it was issues around dimming and the results so far points in that direction and compatibility looks to be the sore spot. So much that Lutron felt it was necessary to withdraw warranty on their dimmers when they're used with a lamp that is not approved by them.
    "Warranty on your Lutron 100 W C•L dimmer or 150 W C•L dimmer or 250 W C•L dimmer will be void if
    used with bulbs that are not on this Lutron compatible bulb list. " -Lutron Electronics
    https://www.lutron.com/technicaldocu..._bulb_list.pdf
  2. #12
    Join Date
    Jun 2012
    NW Ohio
    Posts
    985
    Quote Originally Posted by Electric-Light View Post
    What happened to idiot proofing?
    Come on people, do you really expect joe-blow homeowner to really understand this crap. Just like I'm sure every homeowner tests their GFCI's.
    It should be the smarty pants to make things work together across the board. And keep in mind what would they expect their grandmother to do, or ask what would Jesus do!
  3. #13
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    19,239
    Quote Originally Posted by mopowr steve View Post
    Those of you which marked " didn't like the color " what K temp did you install and did the customer want something that resembles incandescent?
    I prefer 2700K for much of my work although I do get a few people that think 4-5 K is brighter.
    Bah-hum-bug. As far as residential goes. Still commercial I like 3500-4000 K
    I have always advocated Spec35 (3500K) linear fluorescents as a good balance between yellow and blue extremes.
    I have not had much luck finding 3500K in LEDs though.
  4. #14
    Join Date
    Jun 2010
    Posts
    1,928
    All bets are off when you dim them. It does look quite unnatural when you dim down 2700 or 3000K and it just fades down without turning redder.
  5. #15
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    They might be able to idiot proof it but that would also raise the cost, ECs would not buy it .....
  6. #16
    Join Date
    Mar 2014
    Kent Washington
    Posts
    1
    I have the same experienced does not shuts off the led light bulb ar all
    Sent from my SM-N920T using Tapatalk
  7. #17
    Join Date
    Apr 2009
    Williamsburg, VA
    Posts
    5,438
    I marked color. 2700K-3000K is what we usually go with in residential. Commercial I prefer 4000... maybe it's the wall colors work better with it? 2700 and 3500K in those settings looks pretty hideous.
    Never had a single complaint from pindots on countertops from UC LEDs, but I've learned most HOs when they say they want it bright or white do not mean they want their living room lit up like a gas station. Yes, they want a more incandescent type color from LEDs.
  8. #18
    Join Date
    May 2009
    Usa
    Posts
    1,522
    I would say dimmer compatibility is the biggest issue we've had with residential LED lighting.
  9. #19
    Join Date
    Mar 2003
    New England
    Posts
    13,288
    I've found most homeowners to be highly satisfied with LED's.
  10. #20
    Join Date
    May 2009
    Usa
    Posts
    1,522
    Quote Originally Posted by peter d View Post
    I agree but, occasionally we have an issue with dimmer switch compatibility.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
