Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Underground wire
  1. #1
    Join Date
    Feb 2017
    US
    Posts
    13
    Underground wire
    I sent 277v to a lighting circuit and left the numeral and ecg disconnected and the lights work. 12v from the pole to earth and can't find the splice point how is it working???
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  2. #2
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,161
    Quote Originally Posted by hnieves85 View Post
    Very dangerously.
    You need to describe your entire installation. A drawing would help.
    Tom
    TBLO
  3. #3
    Join Date
    Feb 2017
    US
    Posts
    13
    It's a parking lot and I'm trying to find the splice point for the underground pvc pipes
  4. #4
    Join Date
    Feb 2017
    US
    Posts
    13
    I used a meger and the insulation is bad 5 conductor in pipe and I only connected 1 and the rest are safed off
  5. #5
    Join Date
    Jun 2003
    Posts
    9,161
    The fixtures are finding a path for current flow thru the faulted wires, to earth and back to the transformer. Disconnect all the wires and have someone do a fault locate for you. Has this suddenly happened, say after the new fence was put in?
    Tom
    TBLO
  6. #6
    Join Date
    Feb 2017
    US
    Posts
    13
    It's a huge parking lot and I already looked for cut concrete
  7. #7
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,131
    Couple of questions for clarity.
    Why were you called in to troubleshoot?
    Is it possible these are 480V lights?
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
  8. #8
    Join Date
    Feb 2017
    US
    Posts
    13
    No 480 the ballast is wired for 277 and I was doing bucket lighting maintenance
  9. #9
    Join Date
    Feb 2009
    Posts
    9,131
    Fun stuff. Bet no one has an as built. My last parking troubleshoot wound up in a buried ground box that no one knew about. The only thing I know to do is start isolating connections till you find the bad junction or wire.
  10. #10
    Join Date
    Feb 2017
    US
    Posts
    13
    I'm going to use a wire tracer but wanted to see if anyone could explain how the light is working with no return to the panel
Posting Permissions
  • You may not post replies
  • You may not edit your posts
