Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Boundary distances for class 1 div 2 room
  1. #1
    Join Date
    Feb 2017
    fairbanks alaska
    Posts
    5
    I have a 10X14 room that is classified class 1 div 2 group D.The room is used for closed loop butane extraction.It is constructed with 1- 3 hour door for an exit. What is the distance away from that door that is considered to be in the class 1 div 2 area?
  2. #2
    Join Date
    Apr 2004
    Mission Viejo, CA
    Posts
    5,075
    Before addressing your question, I am concerned about a room where the source of fuel is inside. I would want to know how the room is ventilated.
    "Bob"
    Robert B. Alexander, P.E.
    Answers based on 2014 NEC unless otherwise noted.
  3. #3
    Join Date
    Feb 2017
    fairbanks alaska
    Posts
    5
    The proposed HRV is 150 cfm.
  4. #4
    Join Date
    Apr 2016
    Georgia
    Posts
    281
    Quote Originally Posted by martnr View Post
    A quick comment: Class "1" should be expressed as Class "I" - this is industry standard.
  5. #5
    Join Date
    Apr 2004
    Mission Viejo, CA
    Posts
    5,075
    The ventilation rate sounds adequate. Assuming it is, the Division 2 envelope around the door and any other exhaust point should be about 3 feet.
    "Bob"
  6. #6
    Join Date
    Apr 2004
    Mission Viejo, CA
    Posts
    5,075
    Quote Originally Posted by Dale001289 View Post
    Actually, it's the NFPA/NEC standard. I suppose that does make it the industry standard.
    "Bob"
  7. #7
    Join Date
    Feb 2017
    fairbanks alaska
    Posts
    5
    Where do I find this in the code?
  8. #8
    Join Date
    Apr 2004
    Mission Viejo, CA
    Posts
    5,075
    Unless it is an application within the scopes of Articles 511 to 516, you won't. You would need to research the Standards listed in Section 500.4(B) Informational Notes (IN), especially IN. No 2.
    "Bob"
  9. #9
    Join Date
    Apr 2016
    Georgia
    Posts
    281
    Quote Originally Posted by rbalex View Post
    Yep, also used by the American Petroleum Institute: API 500 and 540
  10. #10
    Join Date
    Feb 2017
    fairbanks alaska
    Posts
    5
    Is there an amount of gas that needs to be used in the room to make it Class I Div 2? Or does any amount of gas being used in a closed loop process constitute a hazardous classification for the area? And if there is an amount that would be below the threshold where will that amount be found?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
