jhammer619
I thought I understood 3-phase power perfectly well until I had to size a panel with 240 3-phase High Leg Delta service. Going through old forum posts is getting me more confused.
To get the current on each bus bar (line current), a panel schedule I have adds up all the VA on each phase and divides them by 120V for bus bars A and C, and divides by 208V for the "high leg" bus bar B.
Does this sound correct to you all?
(Please forgive me- I'm used to working with 208Y/120V 3 phase)
The way I envisioned doing this was different: I thought to use separate calculations for 3-phase balanced loads, 2-pole single phase loads, and 1-pole single phase loads.
Say my 3-phase loads add up to 10,000VA. Recalling that Total_VA = Vline_line*I_line*1.732, I calculated 10,000/(240V*1.732)=24A in each bus bar
Right off the bat this differs from the panel schedule macro, which gives me 27.8A on legs A and C, and 16A on the high leg B.
I'll leave it at that for now. Thanks in advance for any help!
