Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
Thread: exisiting 120/277v 2x4
  1. #11
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,704
    Quote Originally Posted by iwire View Post
    I stand by what I said.
    And I can see your definition of "self tapping screw" to be the primary reason. I don't hold that against you
  2. #12
    Join Date
    Dec 2012
    Placerville, CA, USA
    Posts
    18,765
    The code uses the term "thread forming" instead.
    mobile
  3. #13
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    Quote Originally Posted by kwired View Post
    I don't have any problem with my definitions or understanding of the code section.
    Perhaps you have problem understanding what 'generally' means?
    With all that you have said a handy box cover is to thin to tap threads into and be code compliant so thanks for the trip to nowhere.
  4. #14
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,704
    I can't recall ever attaching a grounding screw to a handibox cover, but thanks for the that information if it should ever come up.
  5. #15
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    Thanks for letting me know what you can't recall.
    From the opening post
    Quote Originally Posted by mannyb View Post
    I was thinking of screwing a handy box cover with 1/2'' ko they self tapping a ground scew, what you think is this OK?
  6. #16
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,704
    I lost track of some details in OP by now.
    I guess we are supposed to re read OP before every post to make sure we are on topic
  7. #17
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,614
    Could these be used? I know they are a PITA, but they are a compliant means to attach a ground conductor without worrying about threads.
    Cheers and Stay Safe,
    Marky the Sparky
  8. #18
    Join Date
    Feb 2017
    NJ
    Posts
    6
    Quote Originally Posted by K8MHZ View Post
    Yes
  9. #19
    Join Date
    Jun 2010
    Posts
    1,928
    Nobody mentioned this, but it will draw 2.3 times the current. Is the branch sized generously enough that at 2.3 times, it stays under 80% rule?
    I've never seen documented statement that 120-277v ballasts lock out, but that above would be a reason they might do so. Just depending on how loaded it was on 277v, running on 120v can leave the wiring at varying degree of overload.
  10. #20
    Join Date
    Mar 2017
    Seattle
    Posts
    2
    I believe ground screw needs to be listed for such means. Example I've seen retrofit can light is supplied with a zinc green color tek screw included with the kit. It's kinda catch 22 because inspectors themselves don't know about this and almost always require documents for the screw or retro can light.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
