Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: What type of attic light
  1. #11
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,767
    Quote Originally Posted by kwired View Post
    Don't put them right over the main walkway, then you won't have nearly the chance of bumping into them accidentally. CFL's and LED's won't take the heat as well as an incandescent, but lights in such locations typically don't get hardly any hours on them in the first place. I'd put some incandescent bulbs up there myself, but I am still seeing them in the stores, maybe some of you out there aren't finding them at all?
    I still see incandescents being sold as garage door opener bulbs, and for appliances like ovens.
    Cheers and Stay Safe,
    Marky the Sparky
  2. #12
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    35,680
    Quote Originally Posted by K8MHZ View Post
    I recall seeing an end cap display at Menard's recently of incandescent lamps. Don't recall what wattages were there, but pretty sure 60 watt lamps were in there and maybe 75 or 100. I know they were not GE, Phillips, or Sylvania lamps. Probably some lot of lamps they bought from China and when they are gone they are gone. They may buy another lot sometime, though it may not be exactly same thing.
  3. #13
    Join Date
    Jun 2010
    Posts
    1,928
    strip, tape, or low profile. maybe decorative type light emitting decorations. you want low watt per feet density. localized brightness is bad given the low height.
  4. #14
    Join Date
    Feb 2003
    Bremerton, Washington
    Posts
    7,777
    There are metal cages for keyless lamp holders, and Leviton makes a nice LED lamp fixture that mounts to a junction box
    Moderator-Washington State
    Ancora Imparo
  5. #15
    Join Date
    Jul 2013
    Arcata, CA
    Posts
    383
    In mine, I installed a couple of porcelain fixtures, the furthest one w/ a pull string switch. They are on the (attached) garage light circuit, so there is no chance of leaving it on when not being used. The CFL bulbs have lasted 2 years now, no problems. They draw so little power I don't mind them being on when the garage lights are on.
    In another installation, where garage light power was not as convenient, I installed a porcelain fixture inside the garage w/ a 7 watt bulb that was lit w/ the attic lights were on, because I knew the owner would want to make sure they were out when not in use.
  6. #16
    Join Date
    Mar 2003
    New England
    Posts
    13,224
    For a basic attic without a floor and maybe an air handler, I install keyless lampholders with incandescent lamps. Yes, you can still buy them.
  7. #17
    Join Date
    Jun 2010
    Posts
    1,928
    This stuff is pretty good if you can afford 4" of protrusion and light light distribution is very wide and preferable to thin stuff.
    It can hard wire it it screws into a standard surface mount socket so it ends up like it's flush. It's not undestructible but non-shatterable. Realistically, it ends up matching 100w bulb in a similar fixture since its rated something like 750 or 800 lumen the way it is while a fixture of that type with a bulb is about 50% efficient.
    http://www.homedepot.com/p/Commercia...6241/205890895
    With a low ceiling height, you want the lowest lumen per fixture surface area to avoid bright spots. An ordinary surface mount intended to imitate a can light in a J-box would be quite narrow and have a tunnel vision light.
  8. #18
    Join Date
    Feb 2017
    NJ
    Posts
    6
    Are there any code restrictions if using porcelin keyless fixtures in the attic??? Thanks
  9. #19
    Join Date
    Mar 2003
    New England
    Posts
    13,224
    Quote Originally Posted by jttheclockman View Post
    None.
  10. #20
    Join Date
    Dec 2015
    Montana
    Posts
    2
    I am not a fan of CFL but I would try Allied LH-CFL1. They are low profile, don't break easily and cost less than $20.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
