Results 1 to 7 of 7
Thread: 25' Light Pole
  1. #1
    Join Date
    Sep 2012
    NJ
    Posts
    1,852
    25' Light Pole
    Have a 25' aluminum light pole with arm and cobra head light fixture. They are being mounted to a foundation already in place. There are about 10 of them about 100' apart. Any feed back on how long to install would be helpful. Put together on ground and install with boom truck I'm assuming. I'm thinking two guys can assemble and mount 2-3 in a 7-8 hours day.
  2. #2
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    3,870
    Is the pole base wiring already there? 1.5/hr per pole for install is a conservative estimate. If they need to pull the circuits, all of them will take 2 days. Pole install with two guys should be done within a day.
    Brought to you by Carl's Jr.
  3. #3
    Join Date
    Sep 2012
    NJ
    Posts
    1,852
    Quote Originally Posted by brantmacga View Post
    Yes pole base wiring there. When you say pulls circuits you mean from light pole fixture down pole
    to be spliced in the access/hand hole?
  4. #4
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    3,870
    No I meant pulling base to base
  5. #5
    Join Date
    Sep 2012
    NJ
    Posts
    1,852
    Ok so if wiring is at base and you assembling pole, arm and light on ground and mounting on base you think 2 guy a day for one?
  6. #6
    Join Date
    Apr 2008
    SW Florida
    Posts
    544
    Just did a job: 4 fiberglass 25' poles, new fixtures.
    2 guys, pole truck, 4 hours. (not their first rodeo though)
    1) Remove existing poles, maybe hardest part of the job (rusted nuts).
    2) Drill pole for new fixtures, mount fixtures, run wire down pole.
    3) mount and level new poles.
    4) Connect to existing wiring.
  7. #7
    Join Date
    Sep 2012
    NJ
    Posts
    1,852
    Quote Originally Posted by cpinetree View Post
    Thank a lot for feedback.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
