Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Bonding gas pipe at the water heater
  1. #1
    Join Date
    Mar 2017
    Menifee, CA, USA
    Posts
    3
    I did a main panel upgrade in Temecula Ca. I upgraded a 200 amp center fed panel to a 200 amp solar ready panel. There was a existing bare #4 ground wire to the uffer and a #6 bare wire to the water pipe. I jumped a bond wire at the water heater from the cold to hot water pipe then to the gas pipe. The inspector wanted to fail me because she said that the gas couldn't bonded this way. She said I had to run a separate ground wire from the gas pipe to the main panel. I have asked other inspectors in other cities about this and they have said it is ok. This is the way I usually do it. I couldn't find a code reference. Am I doing this wrong?
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    32,671
    I believe that is okay since the bonding goes back to the panel, however a $6 to the water pipe is not compliant for 200 amps. Look at table 250.66 or 250.102(C)(1)?
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  3. #3
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,395
    What type of gas pipe? Black pipe requires no bonding jumpers.
    Rob
  4. #4
    Join Date
    Mar 2017
    Menifee, CA, USA
    Posts
    3
    Quote Originally Posted by Dennis Alwon View Post
    The bonding would go back through the water pipe and then the grounding electrode conductor that attaches the water pipe to the main panel. 250.66(A) says Where the the GEC is connected to a rod or pipe that it doesn't have to be bigger than #6
  5. #5
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,395
    Quote Originally Posted by Anthony Jattett View Post
    That's for a rod or pipe electrode. The gas pipe isn't an electrode.
    Rob
  6. #6
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    32,671
    Your water pipe is an electrode if more than 10' is metallic and underground. If the metallic pipe has plastic coming in it would still need bonding. For 200 amps these will need a #4.
    The #6 exception is to a rod or a galvanized pipe that is used as an electrode instead of a ground rod. Either way you need a #4 to the water pipe
  7. #7
    Join Date
    Jun 2013
    Massachusetts
    Posts
    29
    Your supplementary grounding electrode doesn’t have to be any larger than #6 but your service ground for 200A has be sized accordingly which is, I want to say a #4, to your water main and gas.
  8. #8
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,395
    Quote Originally Posted by lordofthisworld View Post
    True that for rod electrodes a #6 GEC is all that would be required, if the "supplementary" grounding electrode were a CEE then you would need a #4 GEC.
    Rob
  9. #9
    Join Date
    Feb 2004
    Shelby Twp. MI, near Detroit
    Posts
    343
    Black gas pipe (as opposed to CSST I presume) is not required to be bonded? I did not know that. Please provide the Code reference for my continued edification.
  10. #10
    Join Date
    Jan 2009
    3 Hr 2 Min from Winged Horses
    Posts
    14,163
    Quote Originally Posted by richwaskowitz View Post
    Black or copper gas pipe is bonded by the appliance branch circuit EGC that the equipment is connected to. 250.104(B).
    "Electricity is really just organized lightning." George Carlin
    Derek
Posting Permissions
  • You may not post replies
  • You may not edit your posts
